Abs help
If you're new to the system, please make your first post in this section. Say hello, tell us a little bit about you and your car. We're happy to see you here!
Welcome to the system! If you're a new member we'd suggest making a first post here so that the members know you're alive & on-board!
Kylerhcarlisle
Abs help
Post by Kylerhcarlisle » Mon Nov 23, 2020 3:39 pm
I have been working on the abs brake for weeks now have ran new grounds and I have voltage at my abs module have replaced the module twice and I still get the same code U0121 lost communication abs module, please help!!
2012 chevy caprice 6.0 l77
Re: Abs help
Post by smwalker » Thu Nov 26, 2020 11:31 pm
What you would want to do is hook up a scanner and see if you can communicate with the module. If not then would want to look for a break in the data lines. Most likely a bad terminal at one of the connectors is usually what we see,
here is the data wires diagram.
https://www.chiltonlibrary.com/content/ ... 662707.pdf
Is this a new problem? Like was it OK before and it popped up or did the car have the problem when you got it?
Re: Abs help
Post by smwalker » Thu Nov 26, 2020 11:43 pm
Here is a diagnosis on a jeep but similar tasks to do:
Part 1
Part 2
Re: Abs help
Post by smwalker » Thu Nov 26, 2020 11:52 pm
Oh and just to clarify. you are programming the ABS module each time you install it correct?
