New Owner - 2016 Caprice
lawrence06
Post by lawrence06 »
I just recently purchased a 2016 model as a 2nd vehicle. Came across the site trying to find solutions to a few issues.
Has fair size dent on the driver's rear and I notice in the mornings there is a water puddle on the rear floor on the driver's side. Radio Bluetooth is disabled
Has anyone has this type of water in their vehicle? See picture below
Thanks in advance for any responses
Caprice b.jpg (1.58 MiB) Viewed 2514 times
Sanford
Re: New Owner - 2016 Caprice
Post by Sanford »
The barriers barriers on the doors are bad about leaking, which channels water into the floorboard. I am pretty sure there is thread on vapor barrier leaks if you do a search. You can take a water hose and run water on the outside of the window, with the door open and will probably see water running down the inside of the door where the weather stripping contacts the door.
lawrence06
Thanks, I will take a look at the weather stripping
