Tail light options
Tail light options
Unfortunately one of my tail lights got busted and before going to the dealer I wanted to test the waters and see if there's any other options that might look good.
Re: Tail light options
Converting to LED seems to be about the only option/upgrade. Board member Maurice did it here: viewtopic.php?f=21&t=1253&p=11223&hilit=led#p11223" onclick="window.open(this.href);return false;
Will require you send out your BCM to Chris white for some fine tuning, but all the wiring is in place.
Not even seeing any aftermarket stuff on Ebay AU
Did this on mine with black vinyl. I think it changed the look for the better
- IMG_1973.JPG (3.89 MiB) Viewed 10796 times
WOW I just threw up my coffee laughin.... you seriously covered up your reverse lights? Good luck with that mod sir....I guess you next post will be titled "Backed up into XYZ"
to OP check ebay plenty to find there but they are all OEM type
https://www.ebay.com/itm/2011-2014-Capr ... cZ&vxp=mtr" onclick="window.open(this.href);return false;
Hell yeah! Useless feature!! The backup camera does a fine job (tested it out with the backup lamps unplugged.) not to mention it's a timt film so when plugged in they still light up well enough.
I'm just waiting for my reprogrammed SS silverbox to use the in dash screen
