9C1 to 9C3/G8 console conversion complete
camrat68
Re: 9C1 to 9C3/G8 console conversion complete
Post by camrat68 »
cal30_sniper
Did you use the 92213676 VE/WM shifter in your conversion? I like the way that yours looks and actually thought it reused the stock PPV shifter. None of the "06/07 VE/WM shifters that I can find look like the one you have.
I'm trying to assemble the needed parts to do the conversion in my '12 PPV.
Jim
Jim Chesnutt
1968 Camaro -my first car.
1995 Black/White 9C1 Caprice
the part are from the 08-09 pontiac G8's
camrat68
Post by camrat68 »
cal30_sniper--Do you have any pics of the shifter install that you didn't post?
Every G8 shifter I've been able to locate is gated and doesn't look like the shifter in your pics.
Thanks,
Jim
Jim Chesnutt
camrat68 wrote:cal30_sniper--Do you have any pics of the shifter install that you didn't post?
Thanks,
Jim
Jim you never will find a G8 shifter like the one he used.. Because he got his from Australia from a model that came out 4 years before our cars came out. And a year or so before the G8 was imported. He wrote:
c) Use a 2006-07 Holden VE/WM shifter. They didn't go to tap shift until late '07, so the early cars have a straight gate shifter that includes P-R-N-D-3-2-1 (the method I used)
One thing you will notice is that the Gear indicators are on the wrong side of the shifter in relation to the driver, because in AU the driver sits on the other side of the shifter. One way you can see it not from/for the US market.
EDIT: I just realized there might be a left hand drive version in the Middle east for year 06-07. And yep sure enough there is a part that has gear indication of the correct side if you did not want to hook up tap shifting:
Good luck trying to find one of them!
prostreetmike
Post by prostreetmike »
Following to save... need to do this to mine!! What did it all end up costing??
tedwards0633
Post by tedwards0633 »
This is a great trend! Looks good!
camrat68
Post by camrat68 »
smwalker wrote:
Found several, just can't anyone to ship from Aus to USofA. :(
Jim Chesnutt
Micbrewer
Post by Micbrewer »
Was there anyway to keep the locking mechanism on the shifter that wont allow you to shift out of park unless you press the brakes???
lastcall190
Post by lastcall190 »
Not OP but is your question directed specifically at the shifter he used? Or in general for a G8/9C3 conversion? If former, cant help there. If latter, my shifter came with the little actuator thing and when the shifter is wired up correctly, the brake pedal is needed to shift from park. I could maybe snap a pic this weekend if you like.
Micbrewer
Post by Micbrewer »
lastcall190 wrote: Thu Nov 21, 2019 7:56 pm Not OP but is your question directed specifically at the shifter he used? Or in general for a G8/9C3 conversion? If former, cant help there. If latter, my shifter came with the little actuator thing and when the shifter is wired up correctly, the brake pedal is needed to shift from park. I could maybe snap a pic this weekend if you like.
I am talking about the actuator you described, but I also went with the wm aussie shifter too
