Rear windows not working at all on 2011 PPV 9C1
Posted: Sat Jul 29, 2017 12:34 pm
Good morning guys,
So when I bought the car the rear windows not working wasn't a surprise because every PPV I've ever driven had them disabled,but usually they operate from the driver's side door. I've gone through all the areas I've seen them disabled at in the past but cannot for the life of me figure out why I cannot get them to work. To clarify they do not work from the driver's controls or from the rear doors controls. I've checked the switches at the drivers door and the rear doors and they all seem to be in good working order, I've checked the wiring at all the connections and at the areas it comes through the doors and cannot find anything wrong there, and I've checked the fuses under the drivers side dash. The window motor and window controls fuses are functioning properly because when I remove them I lose functionality to all windows. I've gone under the front passenger seat and switched the plug from the disconnect to the connect as shown by a few different people and still nothing. Can someone point me in another direction to check for things that have been disconnected or cut anywhere? Are there any fuse boxes in the main engine compartment that may have been removed or am I going to get the BCM flashed by a dealer? which I'm really trying to avoid like the plague they are.
Thanks for any help guys
