Need to replace the drivers seat belt tensioner. Somebody welded in an extension to bring it up a few inches and its bugging me. Not only is it too tall, I question its safety. So I've been looking at the gm parts websites. What I can't figure out is the connector they are referring to (oval vs square). Is it the wiring connector or the belt clip itself? Also, I had the car in for an oil change at the dealership. He informed me of the open recall on the ignition key but said nothing about the seat belts and I forgot to ask. Does this matter when ordering a replacement?
https://www.gmpartsdirect.com/auto-part ... r=92237850" onclick="window.open(this.href);return false;
Re: drivers seat belt tensioner.
Can you see the section they welded in? Or is it just up real high?
I assume they are talking about the connector oval vs. square. HAve not ever seen the diffrences side by side. Think I can get the one on a 14. See what that looks like.
So I crawled around with a flashlight tonight and I cannot see a tensioner mechanism. The buckles don't look like any in the parts diagrams. What do I have here?smwalker wrote:Can you see the section they welded in? Or is it just up real high?
- seat belt .jpg (63.44 KiB) Viewed 9524 times
thats not the tensioner, the tensioner is on the other side where the seatbelt meets the seat.
thats just the buckle, which has a plug into the car
if you needs one I can dig around my parts stash and see if I've still got the one from my junkyard G8 seats. I seem to recall the plug being the same
Well that explains why I'm so confused. Now that I know what I'm looking for I'm sure I can find one locally. Thanks for the correction!indianajoe wrote:thats not the tensioner, the tensioner is on the other side where the seatbelt meets the seat.
Greasy, if you still need a stock buckle I found my G8 one
