Center Console Upgrade
- tedwards0633
I am starting my build on my new caprice PPV and I wanted to add this workflow for those who are looking to upgrade as well. I have a list of parts that I ordered below with a brief description. I have not started the install as I am waiting on the all my parts.
I will update the process with pictures as I get going. This is my Phase 1, which I am at about $300 with the center console, shifter boot, T/C & Sport switch.
- found this on Redlinegoods.
https://www.redlinegoods.com/ - Capture.JPG (20.87 KiB) Viewed 18562 times
- Found this on eBay for $80.
- s-l1600.jpg (5.43 KiB) Viewed 19035 times
- I found this website for Salvage yards around the country and was able to find a complete center console off of a 2009 G8
on the Partshotlines site.
https://www.partshotlines.com/ - Q917A_394471.jpg (5.36 KiB) Viewed 19226 times
- Found the shifter on eBay for $90.
- s-l200.jpg (4.1 KiB) Viewed 19226 times
- was able to order the T/C and Sport Mode off of eBay from Australia... $85
- s-l1600.jpg (2.17 KiB) Viewed 19229 times
Last edited by tedwards0633 on Wed Jan 24, 2018 11:38 am, edited 7 times in total.
Re: Center Console Upgrade
Following. I have a 2013 Caprice L77 auto car...
- tedwards0633
I have stared round two
- tedwards0633
I have saved up some more money and purchased 95% of the parts I need, I have them listed below.
I also purchased the connector for the T/C & Sport mode switch using part numbers found on the post
below along with the Center Bezel. I am going to try do without the center support and see if it works. I also have the part numbers that you can purchase the parts on any GM OEM parts site.
I also plan to do a YouTube video on the console removal and install, I will update you all on that once I complete.
Center Bezel: 92268703
T/C Sport Mode switch connector: 13585868
QUICK DISCLAIMER, I DO NOT KNOW WHAT I'M DOING BUT I AM VERY GOOD WITH MY HANDS. ONCE I UNDERSTAND HOW THINGS WORK I AM GOOD TO GO, SO THIS WILL BE GOOD LEARNING EXPERIANCE BUILD FOR ALL FIRST TIMERS!
https://www.newcaprice.com/forum/viewto ... =20&t=1065" onclick="window.open(this.href);return false;
- Found on GM OEM parts store for $60 w/ shipping.
- 39a26547eca231211d8f2e40601a5f70.png (1.57 KiB) Viewed 19000 times
- Found on GM OEM parts store for $123 w/ shipping.
- Capture.JPG (8.9 KiB) Viewed 19000 times
- Found this on eBay for $56
- s-l16004.jpg (2.74 KiB) Viewed 19025 times
- Found this on eBay for $10. I will run this with the radio upgrade from White Auto. I will install this in the center console compartment.
- s-l16003.jpg (6.84 KiB) Viewed 19025 times
- Found this on eBay for $40
- s-l16001.jpg (4.26 KiB) Viewed 19026 times
- tedwards0633
Round Three. I have taken apart the donor console I got from the junk yard for the G8 and clean that thing really good. I used Wipe New to add shine and it looks good. I have an update of what I have done so far below.
- I wrapped all the trim center trim that was sliver in carbon fiber vinyl.
- Carbon Fiber Wrap Trim.jpg (14.78 KiB) Viewed 18945 times
- I cleaned the trim pieces and finished with Wipe New.
- Trim.jpg (16.17 KiB) Viewed 18945 times
- This is the center piece fabrication I went with. I used the passenger door window switch. I removed all the electronic controls and cut the trim piece to make it flat. I then taped the back with Gorila Tape and filed the outside with silicon. I then filled with spackle and sanded down to smoothe surface. I will wrap with carbon fiber vinyl a few times and I should be good. I will send an update to the final piece.
- Center Piece.jpg (11.53 KiB) Viewed 18945 times
- The view from inside.
- center Cubby 2.jpg (14.39 KiB) Viewed 18945 times
- This is the center bubby that I have added the USB and AUX hook up. There was a hold for the 12V plug, I just removed that and it fit like a glove.
- center Cubby.jpg (13.96 KiB) Viewed 18945 times
- tedwards0633
I have my E Brake workflow below.
- Here is what the E Brake Block looks like after I was done.
- E Brake Block.jpg (15 KiB) Viewed 18943 times
- Here is the E Brake Housing that I got from the donor G8. I have removed the cable extension block and cut it with rotary tool to install on the 9C1 cable.
- E Brake.jpg (17.67 KiB) Viewed 18943 times
- tedwards0633
I am done taking out all the 9C1 parts and now will be moving on to install the center console and G8 shifter.
- View from underneath the car where the shifter screws are located.
- Untitled.png (174.16 KiB) Viewed 18902 times
- View of E-brake housing. There were four nuts on the side (2 each side) that have to be removed and the piece slide back and out with some elbow grease.
- E brake housing.jpg (23.59 KiB) Viewed 18902 times
- View of E-Brake cable with adjustment block installed.
- Image-1.png (129.18 KiB) Viewed 18902 times
- View of hole where shifter was removed.
- Image-1 (002).jpg (43.39 KiB) Viewed 18902 times
- View from back of center console.
- Image-1 (002).png (104.06 KiB) Viewed 18902 times
- tedwards0633
I am near the end of all the things I need to do for the center console and I have done some fabrication to save some money. First of all I did have to purchase the Center Support, no way to upgrade with out it. I had to purchase a shifter boot from Redline as the one I had didn't work. I found a way to use the plugs from the old T/C and Sport Mode switch to the one I ordered for eBay Austria. I have the pictures of what I have done below.
- Here is the T/C or Sport switch from the old 9C1. If you pry out the plug you use this in the new T/C and Sport Mode switch.
- image.jpg (183.62 KiB) Viewed 18839 times
- This is the view from the top of the T/C and Sport Mode switch. I just cut off the top where the connector would go so the one from the 9C1 would fit, but the connector only has connections for 3 pins. I used the other one to connect for the other side, and it fit like a glove. It doesn't look pretty, but out of sight out of mind and saves me $100. The first three pins on the T/C SM switch are used and the 4th is not, the fifth one is sport mode. so...
Pin 1 is Power / Remote Pin 2 is Ground, Pin 3 Three is Performance Mode, pin 4 not used, pin 5 is Sport mode. - IMG_0542.JPG (59.33 KiB) Viewed 18843 times
- This is the view from the back of the T/C and Sport Mode switch. I just cut off the top where the connector would go so the one from the 9C1 would fit, but the connector only has connections for 3 pins. I used the other one to connect for the other side, and it fit like a glove. It doesn't look pretty, but out of sight out of mind and saves me $100. The first three pins on the T/C SM switch are used and the 4th is not, the fifth one is sport mode. so...
Pin 1 is Power / Remote Pin 2 is Ground, Pin 3 Three is Performance Mode, pin 4 not used, pin 5 is Sport mode. - IMG_0541.JPG (64.66 KiB) Viewed 18843 times
- I have wrap the center console bezel in carbon fiber vinyl and the center window switch.
- IMG_0544.JPG (74.91 KiB) Viewed 18852 times
- tedwards0633
Quick update. I have ran into a problem with ordering the center support from GM. Part #92222623 & 92258108 have been discontinued. Part #92261672 is the updated part number, but its on back order and no date in sight. I have placed the order but not sure when I will get the part. So for anyone looking to upgrade the center console make sure you can find the center support first. I have fabricated some things to get it installed now, I will upload those pictures soon.
- What I did is cut two pieces of wood and screwed them in my 12v tray compartment. I also cut the 9c1 center support where the 12v compartment was. When I put on the center bezel I used gorilla duct tape behind attached to the radio cage to hold in place. This should hold until my center support comes in, when and if.
- IMG_0549.JPG (78.14 KiB) Viewed 18739 times
Wonder if the plant closure in OZ has anything to do with that? If that's the case, it will get worse for us.
