PPV to G8 seat Conversion
- tedwards0633
I am on to my next project which is my G8 Seat conversion. I have purchased some seat off the Parthotline website and found a set in Michigan. I also found a steering wheel of the other salvage yard site called Hollanderparts. I will upload pictures of the process as I go. I am following the trend from wigid below. Feel free to add any suggestions or tips!
http://newcaprice.com/forum/viewtopic.php?f=20&t=921" onclick="window.open(this.href);return false;
- The steering wheel I found on the Hollanderparts site.
https://www.hollanderparts.com/ - K.jpg (50.9 KiB) Viewed 20341 times
- Here are the seats I purchased
- seats.jpg (17.38 KiB) Viewed 20400 times
- I have purchased this armrest cover from Redline for $50
https://www.redlinegoods.com/ - Capture.PNG (243.78 KiB) Viewed 20440 times
Re: PPV to G8 seat Conversion
I'll be following interested a seat upgrade in my car . Was the armrest just a cover or did you replace it ?
- tedwards0633
It is just a leather cover, this picture is from the Redline website. It was just six screws and you can take the armrest off and the cover is a tight fit, screw back on and it looks OEM. I will upload the pictures from my build.
- tedwards0633
I have competed the swap and it turned out great. Had an issue with the passenger seat rail, it would not slide all the way back via electronic switch. I just went with the old manual that was in the PPV, I am usually riding by myself and I don't see this as a deal breaker. I have the before pictures below, I will upload the finish product once I clean everything up.
I uploaded the final pictures from the conversion and I still waiting on the center support which was order 1/10/2018, but I have not had any issues with the set up I have now. I am also waiting on the cup holder trim to complete the console. I have some quick notes from the build below.
I used Magic Mender Leather Repair Kit to re-dye the G8 seats
I added a Gen III Caprice emblem on the glove box for a personal touch
I painted the entire center console with truck bed liner spray from Walmart
I had to grind out the rivet on the bottom of the G8 seat track to allow the seat to go all the way back
I removed the leather trim piece just above the steering wheel controls, then I re-wrapped the entire G8 Steering Wheel
- The front view from the original interior set up
- 16177145150x640.jpg (50.95 KiB) Viewed 20272 times
- Upgraded G8 leather front seat
- IMG_0577.JPG (80.74 KiB) Viewed 20272 times
- Birds eye
- IMG_0580 (2).JPG (91.19 KiB) Viewed 20272 times
- Original back seats
- IMG_0442.JPG (54.49 KiB) Viewed 20272 times
- Upgraded G8 leather back seat
- IMG_0578.JPG (56.23 KiB) Viewed 20272 times
Last edited by tedwards0633 on Thu Feb 15, 2018 1:45 am, edited 10 times in total.
there is a stop on the G8 electric seat track , you have to knock the rivet out so it goes all the way back
I hate to ask, but are you interested in getting rid of the back seat covers. I would like to change the back seat or seat covers in my wife's car so they match the front seats. Had my eye on an auction of a wrecked 2013 Caprice with carpet and matching seats, but it went for way more than I wanted to spend on a bunch of spare parts.
David
David
- tedwards0633
I have a break down of the G8 Seat upgrade:
Steering Wheel: $120.60
G8 Seats: $326.27
Magic Mender: $65.66
Total: $512.53
G8 Seats: $326.27
Total: $512.53
Hello! Did you have any issues with the airbag light? I purchased a car with the seats swapped, and airbag light on. I thought it was the passenger side, side airbag, but I replaced the broken connector and light is still on. But now the passenger seat sensor does not seem to be working, going to take everything out again and inspect.
2011 9C1, mostly stock, 109k miles... black
looks great, what did you do about the rear carpet at the bottom?
I have the g8 carpet and its a bit short obviously
- tedwards0633
My PPV came with carpet.
