Anyone try this steering wheel?
Re: Anyone try this steering wheel?
Post by s/c'd cav » Thu Aug 20, 2020 4:05 pm
i think there was something slightly different , but having the stock wheel from what i understand gives you what you need
i havent swapped my SS's wheel for the ZL1 wheel yet , and havent put my SS auto wheel into my caprice
AceVL
Post by AceVL » Thu Aug 20, 2020 5:18 pm
VintageIron41 wrote:
Thu Aug 20, 2020 6:03 am
Will a 2014 Camaro LT steering wheel fit a 2014 Caprice without issue? Can the paddle shifter's be made to work with the 2014 Caprice?
Thank you!
I have a 13-15 SS steering wheel I’ll install this On my 2014 Caprice this weekend.
It will bolt up and all electronics will work, paddles have to be wired up separately to the BCM and some areas in HP tuners need to be activated to make them function.
For now I just want to get a better feeling steering wheel.
South Cackalacky
2014 Caprice PPV
2005 Pontiac GTO
1998 Lexus SC400
VintageIron41
Post by VintageIron41 » Sat Aug 22, 2020 6:14 am
Let us know how your steering wheel swap went please!
A613
Post by A613 » Wed Aug 26, 2020 6:54 pm
Thank you!
Camaro's steering wheels from 2012 to 2015 fits the caprice's, you can swap yours to the new one.
Here a link to someone here did it, https://www.newcaprice.com/forum/viewto ... =20&t=2090
I changed mine with the chevy SS, it is a direct swap. I didn't even have to change the controllers from the old one. But the paddle shifts does not directly work. It needs a whole wiring and fuses, to me it is not worth the work and risk. Added Camaro's paddle shift extension just for the look.
Here a pic of mine.
Mine
Screen Shot 2020-08-26 at 8.46.23 PM.png (1.06 MiB) Viewed 395 times
2014 Middle Eastern Caprice, 6.0L.
AceVL
Post by AceVL » Tue Sep 08, 2020 8:20 pm
Hey sorry for responding the late. The swap was seamless. I love the new Camaro steering wheel, it has a much better feel than the standard Caprice one.
The wheel I got had more blue than white colored lights in it, which you could eliminate by swapping buttons, but it doesn’t bother me.
Also my wheel had paddles, so eventually I’ll get the rocker switch, wiring and ECU modified in HP tuners so they will work.
South Cackalacky
2014 Caprice PPV
2005 Pontiac GTO
1998 Lexus SC400
A613
Post by A613 » Wed Sep 09, 2020 5:04 am
If you are done with the paddles, please share the wires and switches! And how and where they are connected. Would love to make mine work!
Yuckydog
Post by Yuckydog » Mon Sep 14, 2020 7:18 pm
Has anyone tried a 2011 Buick Regal steering wheel? I looked at one a while back at a salvage yard.
A613
Post by A613 » Mon Sep 14, 2020 7:44 pm
But isn't the airbag shape is different? If not, and as far as I have learned, as long as the airbag shape and buttons are the same, they work.
As its in a salvage yard, try asking if you could try it there. It is an easy removal and assembly, if it worked get it.
Nate68c10
Post by Nate68c10 » Tue Sep 15, 2020 4:13 am
Thank you!
Here a pic of mine.
Where have you seen a 2014 with the paddles working? If you have a link with instructions I would love to see it becauseI hate how my 2014 shifts and nothing I have changed in hp tuners has made it shift how I would like.
A613
Post by A613 » Tue Sep 15, 2020 7:03 am
Thank you!
Here a pic of mine.
Talk to this guy. (https://www.facebook.com/dustin.manning1), he sells the wires and the instructions that needed to be done, plus a tune to enable the function.
Screen Shot 2020-09-15 at 9.01.11 AM.png (132.65 KiB) Viewed 187 times
