Too cheap for an ss plus, I can’t leave anything alone.
So, I’ve owned my ‘14 Caprice for a couple months now. I’ve slowly started deciding on what I want to do and a late night eBay search, I found a console and shifter from a 2015 SS. At this point, I’m attempting to figure out if the connectors on both shifters are the same. I don’t mind extending the harness, I just want to verify before I tear apart my daily driver. Lol
- Managed to get cup holders AND storage.
- 8BFC2D01-D4C2-466A-96E7-07E47732FE25.jpeg (1.74 MiB) Viewed 11241 times
Re: Too cheap for an ss plus, I can’t leave anything alone.
I did the SS dash, console, shifter & steering wheel swap on my 2016 and to go from the column shift to the floor shift, there is additional wiring. I don't have the schematics in front of my at the moment but,the column shifter only has 4 wires going to two connectors for the shift lock solenoid and gear indicator. The SS floor shifter has a 6 pin connector with the following: Rap Relay Control, LIN network, Tap Shift, Gear Shift Indicator, Shift Lock, & Ground. I made a new harness and connected it at the x209 main body harness connector in the passenger kick & added the missing pins to the bcm. With with the factory Caprice Cluster, the gear indicator will show what gear the floor shifter is in.
You will also need a couple parts to replace the shift cable with the ss shift rod:
GM part # 92259754 - Rod
GM part # 92191383 - Shifter Trunnion
GM part # 92191384 - Shifter Bushing
GM part # 92139143 - Lift Cylinder Bolt
Still need to send Chris my BCM and SS cluster to get programmed for the shifter tap shift/steering wheel paddle shifters, but he is swamped right now.
Column Shift Connectors: Custom SS Shifter Harness:
I actually decided to go ahead and install the shifter today, everything went smoothly and a 52mm gauge will fit where the column shifter hole is. I have yet to extend the harness or anything of the sort.
- D1621353-EE3A-4D56-937E-A804F217B9BD.jpeg (2.73 MiB) Viewed 11226 times
Lord, i’m Sorry about the terrible scaling of the photos.
MS217,
Hey! Welcome to the group. Good luck with your mods and don't be afraid to ask questions and please keep us updated on your projects. And... Yes, please resize your pictures. The max size is listed in the yellow banners. We try to keep the pictures a viewable size.
Thanks,
Thanks,
I’ll be certain to adjust in the future, Maurice. I don’t have much for questions off hand. I’m sure that’ll change as I dig deeper.
- thetonytolbert
Did you evre get your paddle shifters to work?
2015 Chevy Caprice - Heron White
Former South Dakota Highway Patrol Car
Full Holden Conversion
https://www.holley.com/garage/view/7279 ... t-caprice/
- thetonytolbert
RM96, did you ever get your paddle shifters to function? What was entailed?RM96 wrote: ↑Wed Jun 13, 2018 10:03 pm I did the SS dash, console, shifter & steering wheel swap on my 2016 and to go from the column shift to the floor shift, there is additional wiring. I don't have the schematics in front of my at the moment but,the column shifter only has 4 wires going to two connectors for the shift lock solenoid and gear indicator. The SS floor shifter has a 6 pin connector with the following: Rap Relay Control, LIN network, Tap Shift, Gear Shift Indicator, Shift Lock, & Ground. I made a new harness and connected it at the x209 main body harness connector in the passenger kick & added the missing pins to the bcm. With with the factory Caprice Cluster, the gear indicator will show what gear the floor shifter is in.
