Too cheap for an ss plus, I can’t leave anything alone.
Posted: Wed Jun 13, 2018 4:55 pm
by Mulletspeed217
So, I’ve owned my ‘14 Caprice for a couple months now. I’ve slowly started deciding on what I want to do and a late night eBay search, I found a console and shifter from a 2015 SS. At this point, I’m attempting to figure out if the connectors on both shifters are the same. I don’t mind extending the harness, I just want to verify before I tear apart my daily driver. Lol
Re: Too cheap for an ss plus, I can’t leave anything alone.
Posted: Wed Jun 13, 2018 10:03 pm
by RM96
I did the SS dash, console, shifter & steering wheel swap on my 2016 and to go from the column shift to the floor shift, there is additional wiring. I don't have the schematics in front of my at the moment but,the column shifter only has 4 wires going to two connectors for the shift lock solenoid and gear indicator. The SS floor shifter has a 6 pin connector with the following: Rap Relay Control, LIN network, Tap Shift, Gear Shift Indicator, Shift Lock, & Ground. I made a new harness and connected it at the x209 main body harness connector in the passenger kick & added the missing pins to the bcm. With with the factory Caprice Cluster, the gear indicator will show what gear the floor shifter is in.
You will also need a couple parts to replace the shift cable with the ss shift rod:
GM part # 92259754 - Rod
GM part # 92191383 - Shifter Trunnion
GM part # 92191384 - Shifter Bushing
GM part # 92139143 - Lift Cylinder Bolt
Still need to send Chris my BCM and SS cluster to get programmed for the shifter tap shift/steering wheel paddle shifters, but he is swamped right now.
Column Shift Connectors:
- ColumnConnectors.jpg (273.07 KiB) Viewed 11061 times
Custom SS Shifter Harness:
- SSShiftConnector.jpg (338.76 KiB) Viewed 11061 times
Posted: Wed Jun 13, 2018 10:26 pm
by Mulletspeed217
I actually decided to go ahead and install the shifter today, everything went smoothly and a 52mm gauge will fit where the column shifter hole is. I have yet to extend the harness or anything of the sort.
Posted: Wed Jun 13, 2018 10:37 pm
by Mulletspeed217
Lord, i’m Sorry about the terrible scaling of the photos.
Posted: Thu Jun 14, 2018 8:43 am
by Pursuit
MS217,
Hey! Welcome to the group. Good luck with your mods and don't be afraid to ask questions and please keep us updated on your projects. And... Yes, please resize your pictures. The max size is listed in the yellow banners. We try to keep the pictures a viewable size.
Thanks,
Posted: Mon Jun 18, 2018 6:08 pm
by Mulletspeed217
I’ll be certain to adjust in the future, Maurice. I don’t have much for questions off hand. I’m sure that’ll change as I dig deeper.
Posted: Mon Mar 11, 2019 11:56 am
by thetonytolbert
Did you evre get your paddle shifters to work?
Posted: Sun Mar 24, 2019 8:57 pm
by thetonytolbert
RM96 wrote: ↑Wed Jun 13, 2018 10:03 pm
RM96, did you ever get your paddle shifters to function? What was entailed?
