So I have noticed my 2012 passenger floor is wet. I thinking it has to be the AC drain line as I see no AC puddle under the car. I know (99% sure) it is not the heater core as I have hot air and no smell of coolant. DOes anyone know where the AC drain line is? I hate to see what Chevy dealer will charge to clean it out.
....hate living in an apartment.....
Passenger floor wet
Passenger floor wet
2012 PC3 Caprice
3.6 LFX V6 w/ over 200k miles *SOLD* @250,000 Miles.
2013 9C1 Caprice
3.6 LFX V6 with 80k miles
"Dispatch, show me on a traffic stop."
"Uh you can disregard, I pulled the guy that pays my salary, got to let him go."
2013 9C1 Caprice
Re: Passenger floor wet
The AC drain is on the driver side, up on the transmission tunnel. If it has been raining hard, it may be coming through the door panel. There is thread on water leaks that come through the door panel.
David
David
Below are a couple of threads addressing water leaks.
https://www.newcaprice.com/forum/viewto ... =20&t=2219
https://www.newcaprice.com/forum/viewto ... =20&t=1524
David
David
I saw those earlier and read through them. Just trying to figure out exactly where to drain is. I don't know if its different on the 3.6Sanford wrote:Below are a couple of threads addressing water leaks.
David
Id the drain in the area of the oil pan/transmission area?
Sorry for the dumb question. Never had to do this. NOrmal only under the car to change the oil
2012 PC3 Caprice
2013 9C1 Caprice
2013 9C1 Caprice
my 14 was coming in through the door panel , the inner shield wasnt sealed along the bottom
Here is a shot of a car that was hauled to the scrap yard. It is looking towards the rear of the car. The location where the drain grommet is circled. I thought I had a picture of the trans tunnel from inside the car, but I could not locate it.
David
David
- 2013 Caprice, before scrap yard (34) - Copy.JPG (252.68 KiB) Viewed 8661 times
>> Is the drain in the area of the oil pan/transmission area?
I think it actually drips on to the top of the trans, there is no tube directing it past the trans case.
Here is the inside view of the hole. Red arrow.
