SS Front end conversion
Re: SS Front end conversion
I am actually working on a harness for the Caprice HID's from AU and one issue I have come across is they have a leveling motor in them that constantly levels the low beam by taking input from sensors on the front and rear suspension. Doing research I found the SS HID's did not have a leveling motor so that is one thing you would not have to worry about. You would have to increase the wire size for the low beam and ground from like 20 AWG that is factory to 16 AWG. That is doable since you would have everything pretty much opened up anyway so adding wire to a harness not that hard.
