Hello and thanks and thanks for taking time to read this.
Can a G8 select shift be made to work in a 2014 Caprice?
Thank you!
2014 Caprice and G8 Select Shift?
Re: 2014 Caprice and G8 Select Shift?
do not think anyone has tried , since the 14-17's are based similar to the SS
Thanks s/c'd cav, I put a Camaro floor shift in, but now wishing I had select shift. A G8 shifter and console can be had for substantially less than an SS. Yes, the WM is akin to the G8, while the WN series is akin to the SS.
Again, thank you for your reply!
