It is currently Fri Mar 23, 2018 9:37 pm
Post new topic Reply to topic  [ 1 post ]
Author Message
PostPosted: Thu May 18, 2017 10:25 pm
So I had the pleasure of meeting up with hboost today to help install his fog light bezels and harnesses and found out that along the way during the rebuild of his 11 9C3 his front market light harness had gone missing. Since the fog light bulb harness I make piggy backs into the market light harness plug this was a problem. So needed to get him a new harness, checked it out at GM and they want $100 for that sucker. Well that means I am going to be adding another harness to my repertoire of harnesses. This thing can be reproduced for about $7.00 in wire and connectors I estimate. Will be using this thread for a depository of information as I gather stuff for the build. This is not a part I imagine we will need a lot of over the years but good to have options to GM prices.
If any one of you guys parting out a caprice have one of these harnesses speak up for a quick sale!!!
First the parts listing from GM:
Pin out and connector info for connector X108:
X108 Connector Listing:
Black 8 position connector - Yazaki 090-II sealed connector - 7283-1081-30 - Need 1
(but the last two digits only represent color so any on the above table will work)
Toyota part number:90980-10891
Rubber Cavity Plug - Yazaki 7157-8767 - Need 5 (other 3 cavities will have terminals in them)
Female Terminal at connector X108 - Yazaki 7116-4026 - Need 3
Wire seal for Above Terminal - 7158-3006-90 - Need 3
Bulb holder connector (same ones used on the repeater ) :
Connector body - Tyco - 1-967644-1 - Connector - MQS BU-GEH EDS SW2P - - Need 2
Terminal - Tyco - 965906-1 - Terminal - MQSSLD 0.5-0.8,CuNiSi, Sn,INS CRIMP - Need 4
Wire seal - Tyco - 967067-1 - WIRE SEAL 24-18AWG Green MQS SGL - Need 4
Bulb Holder - AC Delco 92193045 (these a bit expensive from AC Delco) - Need 2
Search for:
Jump to:
