Accessory wiring harnesses
Does anyone have the wiring diagram for the accessory harness? I may want to utilize the second battery to power other accessories like an amp.....
- image.jpeg (492.08 KiB) Viewed 11098 times
- image.jpeg (327.32 KiB) Viewed 11098 times
- image.jpeg (307.03 KiB) Viewed 11098 times
1968 K10 short wheel base
2009 Silverado 1500
2013 9C1 - PBM - Sold
2019 Silverado 1500 - LTZ 6.2
2009 Silverado 1500
Re: Accessory wiring harnesses
I think I found hat I was looking for.
- image.jpeg (283.87 KiB) Viewed 11096 times
- image.jpeg (335.32 KiB) Viewed 11096 times
- image.jpeg (293.12 KiB) Viewed 11096 times
2009 Silverado 1500
2009 Silverado 1500
If your car actually has the auxiliary battery, then connect your AMP to the large gauge red wire that terminates in the blue 2 pin connector. That is the power feed from the aux battery if equipped. If not equipped, it will connect to the primary battery. Or if more convenient, connect your amp to the upfit terminal block near the aux battery in the trunk and fuse appropriately.
Garner Ames
Yup got the auxiliary battery. Are there male connectors avalible for these harnesses? If so anyone have the part #s?
2009 Silverado 1500
2009 Silverado 1500
I need a +12 from the battery (on all the time) and a +12 Run (when car is in run position). Can I get it from these cables coiled up under the dash? I'm not getting much from the diagrams without knowing where the components are. Is there a better location under the dash I can get the 2 power sources? Amperage should be low. It's only for a dashcam.
Dave B - Yargnits
2011 Caprice 9C3
2018 Silverado LT
2011 Caprice 9C3
2018 Silverado LT
I realize this is a major thread resurrection. But, did you end up using one of the wires to hardwire your dash cam? Which one did you choose? Did you just tap into it, or remove the socket?
2012 9C3 Detective
2015 GMC Acadia Denali
2010 Subaru Impreza
1986 Chevy K20 3/4 Ton
2007 Mazda 3 (sold)
2003 BMW 540i/6 speed manual (sold)
2006 Chevy Trailblazer EXT (sold)
2010 Subaru Impreza
2007 Mazda 3 (sold)
Yes, it I don’t remember details tho. It’s worked good tho
Dave B - Yargnits
2011 Caprice 9C3
2018 Silverado LT
2011 Caprice 9C3
2018 Silverado LT
