Battery was dead, go to jump and I only have one? questions
Hello I've had my 2012 9c1 for about 2 weeks but have been a member for a while. It only has 19k, hasn't had any recalls done and has a few other electrical issues I'm hoping aren't related to the dead battery ie The horn doesn't work because they clipped the harness while removing equipment and the remote start doesn't work. I have no schematics or even an owners manual, does anybody know of any available online? Also they removed the passenger side battery so now I only have the drivers side batt. I haven't spent too much time looking for a draw from any accessories but I'm going to after I post this. Any input is greatly appreciated. Would one battery be sufficient without all the extra equipment? Has anyone had any similar issues? Everything works fine once I jump it which leads me to believe it's not a charging issue
2012 9c1 20k miles, Holden grill/ badges, radio unlock, g8 rear seat and camaro 20s.... For now
1995 Ram 2500 Cummins 5spd wannabe race truck money pit
1993 Honda Prelude iron (rust) painted car
Re: Battery was dead, go to jump and I only have one? questi
Yea one battery is fine. If you actually had the second battery and they removed it make sure all those cable are secured and not grounding on anyting as those cable are live while the car is running assumng they might not have unhooked the isolator. If you do not even see a ground terminal and cable chances are you never had the extra battery. Every car got the extra battery tray and electrical center but if the did not come with the extra battery they would not include a ground cable.
Keep in mind while these batteries are designed to last a good long while being constantly discharged and boosted on a dealers lot is not good for them. You may just have to replace it early. Get it tested with a good load tester to see how it performs.
Yep, the second battery was an option. Some didn't come with it, but as mentioned above, do have the tray, but no battery terminals or isolation block (all missing from my car).
I agree, have the battery load tested. Police use is hard on batteries and they only last about 4 years or less in that environment, especially with deep charge and discharge cycles.
You can also go into engineering mode and look at the battery charge %. Mine goes down to 60% after the car sits in storage over the winter. And my car has been lightly used (I'm 1st owner, no police use). There is some parasitic draw at all times. So a weak battery will go dead much faster.
Tom (AKA: Storm)
http://www.helminc.com/helm/Result.asp? ... d%5Fmedia=12vPowered wrote:<SNIP>I have no schematics or even an owners manual, does anybody know of any available online?<SNIP>
On a side note, if you have the second battery, does the car use it when starting? Or is it strictly used to run the auxiliary upfit devices? I'm wondering, since I don't have any upfit parts (yet), but wonder if I need to still carry jumper cables in case the left side battery dies when I'm away from home.
They don't appear to be isolated like that in my case?
Yea I investigated that the other day, Key on in RUN position they are joined but as soon as you move to the crank position the secondary battery is isolated so it does not participate in cranking. So if you ever have a dead primary battery you could just leave the key in the run position for 20 minutes to sort of equalize the charge between the two batteries, in theory. May not be enough to crank though if it's really dead.
Crap. I guess I'll add jumper cables to the spare tire well.
