Page 2 of 2
Re: pins for shifter and bcm connectors
Posted: Sun May 07, 2017 6:06 pm
by indianajoe
so i finally got around to enabling this (i ended up getting a bcm pigtail out of a junkyard impala to harvest pins) i moved the tcs and sport mode female pins in the shifter connector to 1 and 4, (i'm rewiring those elswhere) but at x20 was i supposed to remove the wire that was in there or splice into it?
it sort of works, but nothing is shown on the DIC
and i think the car doesn't like it, i got on it a little bit in first with it in selectshift mode and it gor up near 5-6k (wasnt looking at the tach) and lurched, hard. not sure if it bounced off the limiter or something else
Posted: Mon May 08, 2017 9:29 am
by GTPprix
indianajoe wrote:so i finally got around to enabling this (i ended up getting a bcm pigtail out of a junkyard impala to harvest pins) i moved the tcs and sport mode female pins in the shifter connector to 1 and 4, (i'm rewiring those elswhere) but at x20 was i supposed to remove the wire that was in there or splice into it?
Did we program your BCM for this?
Posted: Mon May 08, 2017 10:45 am
by indianajoe
Yes you did, it was a while ago though
Weve had a few email conversations about my vain attempts to get the dealers around me to turn on the remote start, and the last time they screwed up you mentioned the possibility of them messing up your work
Think it needs to be reprogrammed?
Posted: Mon May 08, 2017 1:21 pm
by GTPprix
If they touched it after we did it more than likely yes.
Posted: Mon May 08, 2017 1:33 pm
by indianajoe
Your website says you're closed for another week, what kind of eta would I be looking at to have it checked out?
I actually was gonna send you an email about reprogramming it anyway because I have some aus market led taillights to hook up and I need the taillight splitting you did for Maurice
Posted: Wed May 10, 2017 6:59 am
by 91C02920
The only thing off X2 pin 20 is the sport mode button on the 9C1 shifter. I removed the bcm terminal from X2 pin 20 and moved it to X1 pin 20. In my car, this wire was grey for some reason even though the diagrams show TN for the color. On the shifter side, this was in position 5. I moved it over to position 4.
In my car, before I did this, there was nothing in X1 pin 20.It was empty. X1 of course being the first connector into the bcm, and X2 is the second. Nothing really to splice there, it should just be one wire going from X1 20 to pin 4 of the shifter when you are done. Nothing in X2 pin 20 when I was done.
The splice was done on X1 pin 17, as that also sends reference voltage to the cruise control. Tap into that and run a line to pin one on the shifter connector.
Posted: Wed May 10, 2017 8:08 am
by indianajoe
You're probably right about the pin numbers, but I had nothing in one (x20 I guess) and something in the other (x17) but I took the pin in x17 out and ran the wires from the shifter
Would leaving out the x17 pin make it not show on the display? I haven't tried cruise control since the install do I can't really check that
Posted: Wed May 10, 2017 10:01 am
by 91C02920
indianajoe wrote:You're probably right about the pin numbers, but I had nothing in one (x20 I guess) and something in the other (x17) but I took the pin in x17 out and ran the wires from the shifter
It won't display on the cluster unless you get the cluster reprogrammed to display it. There is different programming for the cluster for a 9C1 vs a 9C3.
So you took the existing wire out of X1 pin 17 and ran a wire from the shifter to X1 pin 17? If you look at the 2nd post from smwalker on the first page of this thread, you see the X17 circuit 1375 goes to a junction where it is split to the shifter and the cruise control. Does your cruise control still work?
Posted: Wed May 10, 2017 3:53 pm
by indianajoe
Haven't checked cruise yet, cars down for some other work right now too
I also noticed my tcs warning light is gone, been on as long as I've had the car. I'll have to try a burnout once it's back on the road
Posted: Mon Jul 03, 2017 10:39 am
by delta88
im trying to follow this and need a little help.
Op is not only adding tap shift to a 9c12 but relocating the trac and sport buttons? Am I getting this right?
Also If you have a 9c1 and want to utilize tap shift after its been enabled one can harvest the wire and pins from other GM cars (someone said Impala?)
End game is I have this all turned on in the BCm and want to add the camaro paddles on the steering wheel.
