Page 1 of 2
Chevy SS Instrument Cluster swap
Posted: Sun Sep 18, 2016 2:33 pm
by Silversled
One of the "aesthetic" faux pas of the interior of my 2014 PPV is its mismatched monochromatic gauge cluster compared to the color display of the myLink 8" center screen. After verifying the cluster pin-outs between my car and the 2015 Chevy SS, I decided to try one.
Well it works mostly but I'll have to contact White Auto to see if they can mate it properly to my ECM and car config (i.e. no bumper sensors/camera, properly reading mileage, etc). However, all basic functions work perfectly. This will end up in my SS dash installation.
Video is here :
https://youtu.be/uXWMmhF1dqk
Re: Chevy SS Instrument Cluster
Posted: Sun Sep 18, 2016 5:00 pm
by elc32955
Nice mod! I had always wondered if the two clusters were swappable, that's a mod that'll directly made the cars more desirable. Now I know you do lose the shift position indicator but gain the temp gauge, that's not a bad tradeoff. One of the things you need to verify for the group is that you do get a gear position indication on the MFD when you shift with the dash (aka "column") shifter. That would render the manual indicator on the PPV cluster 100% superfluous. Also is there an issue with the odometer other then making it read correct miles for your car? I'm guessing that Chris can reprogram the odometer to match...
Posted: Sun Sep 18, 2016 5:22 pm
by Pursuit
Nice mod! keep us informed on the progress.
Regards,
Posted: Sun Sep 18, 2016 5:57 pm
by Silversled
elc32955 wrote:Nice mod! I had always wondered if the two clusters were swappable, that's a mod that'll directly made the cars more desirable. Now I know you do lose the shift position indicator but gain the temp gauge, that's not a bad tradeoff. One of the things you need to verify for the group is that you do get a gear position indication on the MFD when you shift with the dash (aka "column") shifter. That would render the manual indicator on the PPV cluster 100% superfluous. Also is there an issue with the odometer other then making it read correct miles for your car? I'm guessing that Chris can reprogram the odometer to match...
Eric,
All excellent questions that Chris will have to help me answer. I was planning on reaching out to him this week. I've been following his previous work on one of the SS forums and it looks like programming this gauge cluster is a no brainer for him including changing to the red Holden theme and adding additional info that is inherently carried in the GM LAN signal.
As for the gear indicators on the gauges, I'm not too upset if I permanently loose them since I'll be converting the "column" shifter back to the floor shifter (again SS shifter, linkage, and center console).
We'll see what happens. I was dreading having to bolt the stock cluster into the new SS dash. LOL.
Posted: Sun Sep 18, 2016 6:14 pm
by xcidmigs
this will only apply on a 2014+ ppv correct?
Posted: Sun Sep 18, 2016 6:33 pm
by Silversled
xcidmigs wrote:this will only apply on a 2014+ ppv correct?
I can't speak for the electrical interface but physically, yes 2014+. I bought the 2014+ PPV because it shares the same interior/electronic architecture as the 2014+ Chevy SS (Holden Commodore VF2).
Posted: Wed Oct 05, 2016 9:32 am
by ls1mike
Oh man I really like that. Keep us posted!
Posted: Wed Oct 05, 2016 8:36 pm
by Silversled
ls1mike wrote:Oh man I really like that. Keep us posted!
I've been in contact with Chris at White Auto and getting an education on GM's Group A Global Architecture. There are built in security protocols in the components that will brick themselves if they are run in a car that doesn't have the same VIN that it was originally married to at the factory.
I've sent the IPC (cluster) to him and he'll be working to crack the security protocols. We'll see how this works out.
Posted: Fri Oct 14, 2016 11:37 pm
by Silversled
Posted: Thu Feb 16, 2017 2:34 pm
by No Moa
Very sharp!
