Don't have a picture, but is mounted on it's edge, in a black plastic holder with the different colored connectors on the bottom. The holder is attached to the console side of the steering column. I would recommend taking a picture of the color sequence of the connectors installed before removing them. Once you have the connectors removed you can release the BCM from the holder or remove the holder and BCM together. The holder is retained by three tabs.
Regards,
Couple questions about White's BCM programming
Re: Couple questions about White's BCM programming
Here is a diagram looking at the back of the dash. BCM is number 2 with the 7 slots facing down. They are color coded and keyed so you cannot put the wrong plug in the wrong slot.
Steps are disable the SIR system (disconnect negative cable, wait 15 minutes)
Then there are 2 retaining clips that release the module from it's bracket.
Awesome thanks!smwalker wrote:Here is a diagram looking at the back of the dash.
Thanks Maurice!Pursuit wrote:Don't have a picture, but is mounted on it's edge, in a black plastic holder with the different colored connectors on the bottom. The holder is attached to the console side of the steering column. I would recommend taking a picture of the color sequence of the connectors installed before removing them. Once you have the connectors removed you can release the BCM from the holder or remove the holder and BCM together. The holder is retained by three tabs.
Regards,
Thanks guys got to got to work
Took a couple pictures and wanted to update this thread. I'll be sending mine to Chris next week. You're looking directly above the gas pedal.
Take the airbag knee bolster off by undoing 2 silver 10mm bolts, two black T20 torx screws and pull straight out towards the seat to release clips. Disconnect airbag sensor in back by taking slide lock tab out and depressing top of connector.
BCM connections are depress tab and pull, and the BCM bracket is straightforward as mentioned earlier, pop out two bottom clips, tilt and it releases. You'll have to finaggle it out though (bracket with BCM method).
You crawl in all cattywampus and such but it's a thirty minute job tops, extra 20 minutes or so with the battery disconnect.
- IMG_20190111_174454-768x1036.jpg (168.46 KiB) Viewed 6242 times
- IMG_20190111_174448-759x1024.jpg (149.27 KiB) Viewed 6242 times
- IMG_20190111_173307-1024x759.jpg (163.1 KiB) Viewed 6242 times
- IMG_20190111_173303-1024x759.jpg (164.78 KiB) Viewed 6242 times
Active Duty USAF
Active Duty USAF
