CD stuck in CD Player
twofi5e
Post by twofi5e » Sat Nov 26, 2016 1:47 am
Hey all, I did a search for stuck CD's and came up with nothing. I placed a CD in my car tonight that was a burned CD from years ago and upon taking the CD, the display read "loading CD" and then would switch between "ejecting CD" on it's own without me touching anything on the car. It cycled between the two screens about 5 or 6 times before going back to the default screen and remaining there. After repeated attempts of pressing the eject button, nothing would happen. Tried turning the car off and back on and still nothing. Has anyone else experienced CDs becoming stuck in their car? If so, what steps did you take to get it removed? Also, this was not the first burned CD that I put into my car. I had put a least 3 or 4 other burned CD's in my car prior to this one getting stuck and they all played just fine and ejected with no issues.
-Kase
Maryland
____________________
2012 Chevy Caprice PPV 9C1
2001 GMC Sonoma SLS(r.i.p.)
BMase76
Re: CD stuck in CD Player
Post by BMase76 » Thu Jan 26, 2017 1:23 am
Had a somewhat similar experience with my radio when it froze and stopped responding to inputs. I had a CD in and I pressed and held the advance button to skim through a track to a certain spot, and the radio didn't like it at all. The display froze and the CD stopped playing, and button pressing did nothing. I was able to pull the radio fuse (instead of unplugging the battery) and I left it for a good while. Plugged it back in and I got functionality back...had to reset the time though. Maybe it will work for you....good luck!
twofi5e
Post by twofi5e » Tue Mar 21, 2017 9:47 pm
BMase76 wrote:Had a somewhat similar experience with my radio when it froze and stopped responding to inputs. I had a CD in and I pressed and held the advance button to skim through a track to a certain spot, and the radio didn't like it at all. The display froze and the CD stopped playing, and button pressing did nothing. I was able to pull the radio fuse (instead of unplugging the battery) and I left it for a good while. Plugged it back in and I got functionality back...had to reset the time though. Maybe it will work for you....good luck!
Hey, I'm just now seeing this reply as I don't use the board very often. However one day I just randomly pushed the disc eject button as I started doing everyday since it got stuck and it popped out. Still not sure what made it get stuck but it was in there for about a good month and a half to two months and every day I would get in the car and try the eject button and nothing would work. Makes me never want to put another disc in there.
-Kase
Maryland
GTPprix
Post by GTPprix » Fri Mar 24, 2017 3:32 pm
This is going to sound crazy but take the faceplate off and reseat it. I've seen it where the faceplate is just ever so out of alignment that it hits the CD and results in a loop.
Chris White
http://www.whiteautoandmedia.com" onclick="window.open(this.href);return false;
2015 Jeep SRT - Stock for a hot minute.
2016 SRX - Custom BCM/HMI - More to come
2016 Yukon Denali XL - Custom BCM/HMI/IPC
