Driver's seat controls
Posted: Fri Dec 16, 2016 8:54 am
Wasn't sure if this fits best here or in "interior"....either way, just needed to share.
Recently I reached down and happened to drag my hand across the lumbar inflate/deflate rocker switch. The bezel popped off, to my surprise. After finding the piece (hard to see with black carpet), I was pretty sure it was damaged. I'm guessing it may have somehow been damaged when the seat belt recall work was done, since that panel on the seat was removed in the process.
Took a little digging to find, and I just wanted to pass along the info, in case anyone else may have lost or broken this part. For what it is, the cost is ridiculous--fortunately my local parts guy backed it into the belt recall warranty job and just handed it to me.
http://www.gmpartsdirect.com/oe-gm/92258946" onclick="window.open(this.href);return false;
Note the nomenclature--GMPD calls it a knob, and the packaging from GMNA SPO identifies it as an "actuator"--I would classify it as a retainer or bezel.
Here are pictures - as noted on the bag the part came in, Holden does call it a BEZEL - go figure!
