Adding fog lights to the Caprice
PPV
Re: Adding fog lights to the Caprice
Post by PPV »
xcidmigs wrote:Yes thats the ones i want to use off a 2011 Holden Berlina from Australia.
Part Numbers for the black bezels only are 92231792 and 92231793
Can someone help with the black only bezel part #s? These are showing as chrome.
Btw holdenpartusa.com will try and stock these and other parts like spoilers and fender side markers new direct from holden.
1968 K10 short wheel base
2009 Silverado 1500
2013 9C1 - PBM - Sold
2019 Silverado 1500 - LTZ 6.2
Post by xcidmigs »
I don't know why those part #'s are showing up as the chrome to you, I posted them up after getting that order placed by CP who is the one who looked them up, as pictured they are clearly the plain black version. Chrome ones are listed on page 1 here and have different numbers
I guess going from this listing the chrome set actually comes in 2 pieces per side?? From post on first page:
92255233 Base – chrome front fog - LH
92255234 Base – chrome front fog – RH
92266067 Cover – front fog lamp – LH
92266068 Cover – front fog lamp – RH
roman1978
Post by roman1978 »
Guys I could be wrong but the fog lights you are buying from Australia look like the same ones used on 2014 Chevy SS they sell aftermarket ones in USA for like $25 each
I hope that might help
roman1978 wrote:Guys I could be wrong but the fog lights you are buying from Australia look like the same ones used on 2014 Chevy SS they sell aftermarket ones in USA for like $25 each
Roman when we talk about "Fog Lights" we are really only talking about the Bezels or things the light modules mount into. The trick is to get the bezeles (chrome trim or Black out) from AU and use the light modules available through GM in the US (or the aftermarket ones, they look good as well). So it's a sort of mix and match situation.
Anyone who has done this had a question on the mounting hardware needed. Bill paired down the list of mounting hardware from the 4 items to 3 here:
Mounting hardware
9114472 Nut (4) (blue plastic)
11589015 Bolt (4)
13144822 Bolt (4)
I see where the blue nuts are needed and 4 bolts go into them, but what are the other 4 bolts for? THe bezels just snap into place yes? Not bolts holding those on correct?
Post by xcidmigs »
yeah i have no idea, i did mine a month ago and just bought 4 generic bolts and nuts at my local Lowes store.... the front parts do just snap into corresponding slots in the bumper itself and then the lights bolt onto those..... Sorry no clue but I'm still lost on how to activate them using the factory G8 switch and PPV wiring harness so what do i know....
Thanks anyway XC, Yea I be with you in a few more weeks on that wiring issue. Hopefully an elegant solution is to be had.
Post by xcidmigs »
i just need to figure out how to connect to the factory wiring harness the solution is to switch the ground wire on a relay its not hard.
OK tore into this a bit more this week. Was able to transfer the terminals from the Australian fog light harness to some empty spots on the Side marker Light Harness. This will ensure only one connector for all front bumper items. Need some corresponding terminals for the car side connector. The connector is a Yazaki Product. Details in the pic below:
Think I need terminal 7114-4026 along with a rubber sealing ring and that appears to be part number 7158-3006-90
Data Sheet: http://inventory.smdinc.com/search/pdf/7114-4026.pdf" onclick="window.open(this.href);return false;
Catalog for the 2.3mm (.090 inches) line of sealed connectors: https://connectors-catalog.sys.yzk.co.j ... ectors.pdf" onclick="window.open(this.href);return false;
Now to find a vendor without a $50 minimum.
