Radio - USB connection...
Re: Radio - USB connection...
I'm making the USB cables... I still have to test it to make sure everything is good...
As for the 3.5mm aux front inputs, I have a USB/3.5mm receptacle, and am figuring out the detection signal circuit. I'm still working on sourcing the plug for the 3.5mm side... the other ends of the wires have to be added to the radio wiring harness connector...
Will let you guys know when I get it all figured out!
Thanks,
Tom Slick
Thanks,
Tom Slick
Tom
I am interested. Can you post the details or pm me with pics of the install and price.
Derek
Derek
2009 Tahoe SSV 4x4 soon to be 2012 Caprice PPV Black/Black - DD/Work
1997 Camaro SS #1925 6spd -Cam/exhaust suspension etc
1967 Camaro SS 350 numbers matching being restored/Not stock
2003 Silverado 1500HD - Driveway Statue
I really would like one too please !!!!
2011 9C1
Heron White
Original title holder bought with 61 miles on the odometer
Heron White
USB connector kits - I can sell you the connector kit for the USB cable... you will have to assemble it yourself... you can use whatever length usb cable you want, cut one end off, and then put this connector on it.
$20 - shipped... Sound reasonable enough? Paypal accepted!
Thanks,
Tom Slick
Thanks,
Tom Slick
USB radio parts
These were given to me so I'm passing it along. Make sure you buy extra pins. They are very small and a pain to crimp
GT8-2428SCF - x4
GT17H-4S-2C - x1
GT17HS-4S-5CF - x1
GT17HS-4S-HU - x1
Mouser.com
The audio connector for the USB/Aux plug should be this one
Connector - AIT2PB-06-1Ak
and
Terminal - SAIT-A02T-M064 (GM does sell a terminated lead under part number 13575867, but they are about $7.00 ea
http://www.docstoc.com/docs/147016546/AIT-II-connector
Now to just find a source
The GM connector has a few different part numbers
19167753 ~136.00
13577043 - ~73.00
GT8-2428SCF - x4
GT17H-4S-2C - x1
GT17HS-4S-5CF - x1
GT17HS-4S-HU - x1
Mouser.com
and
19167753 ~136.00
13577043 - ~73.00
Yep... Mouser is about 2 miles from where I work...
Later,
Tom Slick
Later,
Tom Slick
I might have found a supplier for the 3.5mm receptacle connector (AIT2PB-06-1Ak)...
Later,
Tom Slick
Later,
Tom Slick
For about $170 you can get 350 connectors and 3500 terminals shipped to your door directly from the manufacturer. Make a few with leads and sell them for way less than OE and still have plenty left over plus make a profit doing it
2009.5 PBM G8 GT - CAI, Headers, Tune
They are available at the salvage yards also.BlackGT5 wrote:For about $170 you can get 350 connectors and 3500 terminals shipped to your door directly from the manufacturer. Make a few with leads and sell them for way less than OE and still have plenty left over plus make a profit doing it
This is a part on the 2008-2009 G6 and Malibu.
On one year it is the IP dimmer switch connector and the other year it is the Headlight switch connector.
This is also the brake pedal position switch connector on many cars and trucks
-Greg
Tom,Tom Slick wrote:I might have found a supplier for the 3.5mm receptacle connector (AIT2PB-06-1Ak)...
Later,
Tom Slick
I pickup up this GM harness that comes with the connector and about 3' of wire.
- audio harness.JPG (1.19 MiB) Viewed 15094 times
