It is currently Sat May 26, 2018 8:58 pm
Post new topic Reply to topic  [ 6 posts ]
Author Message
PostPosted: Thu Aug 31, 2017 4:15 am
Offline
A while back, I installed a second set of rear speakers in my Caprice. Awesome, I have "surround sound" in the car now. The speakers I initially installed were cheapie Rockford Punch series 6 1/2"s. Their output was purely noise, no bass, all treble. I then upgraded to a tried and true set of MTX Terminator 6 1/2s. Same thing, a little better sound, but still almost no bass.
Is there a setting/change inside or re-coding of the radio that needs to be done for better rear sound output from factory radio outputs? Chris White?
_________________
2014 Phatom Black 9C1 (Toy)
Top
 Profile
PostPosted: Thu Aug 31, 2017 5:25 am
Offline
have you checked to make sure the positive and neg wires are on the correct ones ? if you mixed the wires on one speaker the bass will drop out , easiest way to tell is switch the balance left or right , and if the bass picks up then one speaker is wired opposite of the other , also check that you are running the recommended ohm rated speakers
other wise adding a sub and amp is the best way to get more bass , or add something under the rear deck to make up a box for the rear deck speakers
Top
 Profile
PostPosted: Thu Aug 31, 2017 5:51 am
Offline
When I originally installed the rear speakers I think I looked up the polarity on the factory speaker and spliced from there. I cant recall, that didnt cross my mind to reverse what I have. Both are wired the same and they have different pin/connectors for positive and negative. I figured that I had a cheapie speaker ($30/set) and that was the issue.
And at this point, I dont think ill be running deck speakers.
_________________
Top
 Profile
PostPosted: Thu Aug 31, 2017 6:12 am
Offline
It is quite possible what he said above, however you said you purchased Rockford Fosgate punch series speakers, but then said they were a $30 set. That would be their prime series. I swear by Rockford (just as much as I swear by MSD, KN and Royal Purple) but punch is a must have (normally 60 bucks for a pair). The ohm rating could also be an issue, or you could also benefit from running a thicker gauge speaker wire. I have installed plenty of Rockford Speakers in my day, and I have never been disappointed and neither have my friends. I also use gold plated female connectors as well. In my 03 Silverado I cut like 6 inches of wire off and spliced 14 gauge in to let them get more power (at least at the end of the wire). My truck has 6.75 punch Rockfords with 1 inch tweeters, 4x6's in the suicide doors, and a 1000 watt 2 channel amp with two Rockford Fosgate Punch P2 12" woofers. Cleanest and clearest system I have ever heard. I will be installing rears in my 13 Caprice and I will let you know if I have any issues (once Chris White fixes my radio the dealership bricked).
_________________
03 Silveraydo 4.8 - Registered 570 ft lbs at 3900 RPMs, and 396 HP at 4900 RPMs. No tune, no cam.
13 Caprice 6.0
Top
 Profile
PostPosted: Thu Aug 31, 2017 6:58 am
Offline
for my 14 , ill be putting in rear deck speakers , unless i happen to pick up some holden caprice door panels with the factory speaker grills , im not paying 700ish per door panel for new ones
the SS sedan speaker grills for the rear deck were about 30.00 each , then have to cut the rear package tray for the holes and screw them in , the do fit the groove in the package tray , then figure out what to do for mounting , i also plan to run a amp and sub in the trunk
Top
 Profile
PostPosted: Thu Aug 31, 2017 8:16 am
Offline
I hear you man. Please PM me or link those speaker grilles, I'm also interested in installing back decks. And if you're gonna run a sub and amp I would highly recommend Rockford. My amp was about 400 (I don't know your budget) and the Punch P2 12's about 90 each. I don't know your setup but you would only need one Punch P2 and a sealed or ported box for plenty of bass. (I prefer sealed because it is cleaner sounding and doesn't rattle like ported). In my opinion, you cannot possibly go wrong with Rockford and their quality and bang for your buck is unbeatable. Kenwood is made by JVC (head unit in my truck is JVC, 22 watts per channel, max volume of 50 and cant turn it past 23 without my ears bleeding) and they also make good speakers as well. But I am sold on Rockford.
Each Rockford punch speaker can be amped to 120 watts as well. If you bought an amp for the speakers.
I haven't taken the rear panels off yet, but I plan on doing that and figuring out what size speaker I can cram in there, then marking an outline on the panel itself. Drill holes in the center and finish off with a 2.5" hole saw. Then sand or exacto knife any rough edges. Install speakers to the sheet metal and the grilles to the outside of the panel. Because our speakers are suffocating behind the panels as long as you make it look good, you're increasing the value of the car.
_________________
13 Caprice 6.0
Top
 Profile
Search for:
Jump to:
