Horn Question 2013
bluethunder
Horn Question 2013
Post by bluethunder » Tue Oct 17, 2017 11:41 pm
My horn does not work on my recently purchased 2013. Is the horn on active police cars hook up to run the siren ?
Re: Horn Question 2013
Post by smwalker » Wed Oct 18, 2017 1:43 am
There is a place where they can interrupt the horn circuit to control a siren. Behind the glove box at the firewall is a harness with a wire coming out of it with two connectors on them. If they are connected make sure they are connected with the same color wire. If disconnected hook them up that usually fixes the horn. 11-13's it is a brown and black wire 14+ Green with a white stripe.
So here is an example were they have connected in some black wires into the circuit. You would remove those and plug the Brown/Black halves back together.
bluethunder
Post by bluethunder » Thu Oct 19, 2017 1:55 am
Thanks Steve.......will check this out.
bluethunder
Post by bluethunder » Fri Oct 20, 2017 12:34 am
Great tip found the wire with a few things hanging off it that shouldn't have been there. Reconnected and boom...........a nice horn sound. Thanks for the info. Now I just need to get my overhead red and clear police lite to work. Checked it today and no power going to it. ??
Post by smwalker » Fri Oct 20, 2017 4:06 am
Where you check it at the bulb contacts or the connector? You have an orange wire at the connector?
I believe the orange wire is circuit 1732 and that goes right to the BCM so if you leave the light on when you turn off the car and shut the door it will turn off the light after 10 minutes. No fuse for that so if you do not have power at the wire then we gt a BCM problem.
CapriceBTR1
Post by CapriceBTR1 » Fri Sep 14, 2018 9:20 pm
You're post on how to fix the horn in my Caprice made my day when I came across it! I traced the brown and black wire like you said then connected them. Horn works!! Thank you so much.
