Cruse control problem
Car-o-sexual
Post by Car-o-sexual » Fri Oct 19, 2018 2:49 am
So I am having a intermittent cruise control problem that will just shut off the cruise and you can't use it again until you shut it off. Anyone else have this?
1998 GMC Sonoma 5.3 swap
1998 Chevrolet camaro
2013 Chevrolet caprice 9c1 dod delete stage 1 tsp cam
2000 chevrolet astro
1957 Chevrolet bel air coupe
Re: Cruse control problem
Post by smwalker » Fri Oct 19, 2018 3:42 pm
What will help you narrow it down is if you can get a read on the codes that are present. They would not be P codes that would set off a check engine light but rather B or U codes for Body and communications codes that would help you determine what is going on. Would need a high level scanner to read those.
Here is a description of the system:
https://drive.google.com/open?id=1PjWd- ... BlC6AFHCgY" onclick="window.open(this.href);return false;
And wiring diagram for the BCM side
Car-o-sexual
Post by Car-o-sexual » Thu Nov 22, 2018 7:30 pm
So finally got around to checking my error code and I got a p0575 Cruise Control Input Circuit. Does that mean I have a bad relay?
Post by smwalker » Sat Nov 24, 2018 7:47 pm
THis diagnostic description would seem to indicate it is a problem between the BCM and ECM. But that is serial data so nothing you can really diagnose with electronic test tools. Gotta break out the big daddy scannes and tech 2's for this.
Post by smwalker » Sat Nov 24, 2018 8:00 pm
Although wondering if one of the diodes in the multifunction switch are bad if taht wold be the source of your issue in that it is sending the wrong voltage to the BCM.
For $45.00 might be worth a try even if you can't return it. Just a PIA to get to and replace.
https://www.amazon.com/ACDelco-92177957 ... B00S0NLKL2" onclick="window.open(this.href);return false;
Car-o-sexual
Post by Car-o-sexual » Sat Nov 24, 2018 8:25 pm
I was kind of thinking that may be going bad, as a cop car I am sure that jumping in and out of the car they probably jammed there knee in it quite a few times :shock:
