AUX cables for the IQ/PPV radio
Does anyone have an AUX cable for the IP/PPV radio?
I'm getting it reprogrammed by Chris White and am having a hard time finding this cord.
Thanks for the help.
Re: AUX cables for the IQ/PPV radio
You are getting the Audio Aux In cord from me along with the USB. Do you mean the Video in Cord?
Hey sorry, right I'm getting USB cord for you, I meant the video cord for the back-up camera.
Following!
I'm currently trying to do the same as far as adding the DVD +/- and Video in +/-. I'm glad I didn't pop for a 20 pin connector since I don't have anything to connect to. My spare 2011 silver box has it but neither of my recently programmed 2012 silver boxes have it.
Reading the old RCA thread, viewtopic.php?f=21&t=1250&hilit=solder
Pin 1 DVD video signal (-) negative
Pin 2 DVD video signal (+) positive
Pin 3 Reverse camera video (-) negative
Pin 4 Reverse camera video (+) positive
Do you have to attach the shield wire and foil to anything or can you just clip it off?
Jim Chesnutt
1968 Camaro -my first car.
1995 Black/White 9C1 Caprice
The wire shielding isn't attached on my setup. Just the 3 wires in the cable I used as it was a headphone type cable with a shared negative The negative went to the connector cover/shielding, and the positives were attached 1 to each positive pin. The wire shielding was just clipped back and not connected. Still working well on my car.
camrat68 wrote:Following!
Does anyone know if this cable will fit a 2013 Caprice?
https://jhpss.com/shop/interior-accesso ... era-cable/" onclick="window.open(this.href);return false;
No idea. Does it plug into the 20 pin connector?
I just finished doing the backup camera connections for our '12 and '13 silver boxes. I enlarged the hole to be able tuck the wires inside the case to re-install the radio and tied fishing line to the cables to make retrieving them easier after installation.
- secured wiring
- PA253230m.jpg (234.69 KiB) Viewed 10126 times
- Case lightening mod
- PA253233m (2).jpg (162.54 KiB) Viewed 10126 times
- PA253231.JPG (213.17 KiB) Viewed 10126 times
Jim Chesnutt
Is your setup home-made?
I have the 20 pin connector I bought only to find my radio didnt have the connector, like camrat. I ended up just soldering a home made harness directly to the board in the radio.
If you want i will sell you the connector for what it cost me. I bought it from envyous customs in Australia. I would just say make sure your silverbox has the connector first.
2011 PPV 9C3
PM sent. Thanks!
