Adding extra sound deadening material to the floorboard, I came across the plug. It'll plug into either side and appears as a single blue wire.
Upfitter wire? What does it go to? Thanks.
Harness under passenger seat
- IMG_20190205_133110.jpg (151.42 KiB) Viewed 4273 times
Active Duty USAF
Active Duty USAF
Re: Harness under passenger seat
i think that is the jumper for the rear windows
Yes the disconnect for the rear power windows. You can toss the blank connector if you want. It is a civilian now.
Gotcha, thanks.
Active Duty USAF
Active Duty USAF
