NEW starter problem
Cgthaxton
NEW starter problem
Post by Cgthaxton » Sun Mar 31, 2019 8:55 pm
Ok, My starter in my 2012 failed and I ordered a brand new “Duralast Gold” starter from Autozone. I replaced the starter and crank sensor while I was in there. When I start the car you can hear the starter grind on the flywheel like an older vehicle needing the starter shimmed. Has anyone ran into this or have any insight? My thoughts are to pull it out and try replacing it again. Battery is good also.
Re: NEW starter problem
Post by s/c'd cav » Mon Apr 01, 2019 7:12 pm
you probably need to shim it
Cgthaxton
Post by Cgthaxton » Tue Apr 02, 2019 12:37 am
These starters aren’t shimmed. Took that Duralast back and replaced with AC Delco. It’s just fine now.
v8suprcapric
Post by v8suprcapric » Sat Oct 17, 2020 1:02 am
So how hard is it to replace the starter? My only experience is old Chevy's.
