In a 2014 WN Caprice, can a 2014 Chevy SS instrument cluster be swapped in? If so, plug and play? Will it activate the SS coolant temperature and otherwise swap with the color center display?
Thank you!
PS I just found the thread on the swap.
Chevy SS instrument cluster swap?
Re: Chevy SS instrument cluster swap?
I know you said you found the other post but no these need to be custom programmed BEFORE plugging them in.
Chris White
2022 3LT Red Mist Coupe
2023 70th Anniversary Z06 HTC
2023 Escalade V
2022 Camaro ZL1 M6
2023 Escalade V
2022 Camaro ZL1 M6
