2012 Caprice - Head Light Bulb Size List - Part Numbers
Schul274
Post by Schul274 » Tue May 14, 2019 7:38 pm
Hello,
I had trouble finding the list of headlight part numbers when I was looking, so I recently swapped mine and wanted to help others out.
Low Beams (projectors): H11
High Beams: H7
Running lights (upper) 194s [group memeber recomended a 921 bulb, uses the same socket but improved brightness)
Turn Signal: 64136 (weird size, napa had it)
Fog Lights/DRLs (optioned): 9005s
Side Markers: 194
Some LED's that a FB group member recommended (links don't work):
DM ASTAR 2800 lumens Extremely Bright Error Free 921 912 3020 Chipsets LED Bulbs For Backup Reverse Lights, Xenon White
Auxbeam LED Headlights F-16 Series H7 LED Headlight Bulbs with 2Pcs of headlights 60W 6000lm CREE LED Chips Fog Light - 1 Year Warranty
Auxbeam H11 LED Headlight Bulbs F-16 Series Extremely Bright Led Conversion Kit 60W 6000lm SMD LED Chips Fog Light - 1 Year Warranty
Auxbeam 9005 LED Headlight Bulb F-16 Series LED Headlights with 2 Pcs of Led Bulbs 60W 6000lm LED Chips Fog Light - 1 Year Warranty
Re: 2012 Caprice - Head Light Bulb Size List - Part Numbers
Post by elc32955 » Wed May 22, 2019 12:04 am
Thanks for the info and detailed pictures! Just FYI - there is a limited common parts index off the main site menu (not on the forum section itself but off the front web menu), sorry you didn't see the bulb listing there before you had to investigate yourself.
gregthrey
Post by gregthrey » Thu May 30, 2019 7:53 pm
@Schul274 you can easily find this info on sylvania or philips website Image
nice job your lights look great, nice white color too!
i got similar results upgrading to LEDs, indeed as you pointed out, third gen caprice sport an H11 low beam and H7 high beam
i ordered these about two years ago they still work really well
H11 (low): https://www.xenonpro.com/h11-single-bea ... lights-kit
H7 (high): https://www.xenonpro.com/h7-single-beam ... lights-kit
No marathon gets easier later.
