Dual-colour side turn signal LED lights!
Stumbled upon this interesting product, which combines an amber side turn signal with white LEDs which I presume act as puddle lamps. A bit of installation required but interesting all the same.
http://www.exledshop.com/exled-custom-l ... -copy.html" onclick="window.open(this.href);return false;
Re: Dual-colour side turn signal LED lights!
I am ordering these for my car. Great find.
1996 DGGM Impala SS
Member of Carolina Holdens
1996 DGGM Impala SS
Yeah, but our cars do not have side lights aready to be modified. So you would first have to have the ones with the lights first. I have the Whelen Sidekicks in amber on mine, but the LEDs are too bright to use as marker or turn signals. I was going to see about dimming them, but never got around to it.
There is now a cheaper version of the Whelen for $180 compared to them at $300. It is from 911 Signal USA.
I have repeaters from C.P. on my car. We used a, what I would call it, Diode that was for LED lights on a Harley that pulls power from both the Turn signal and the head lights or running lights. Mine pulls from the head lights. When the headlights are on the voltage is decreased to the repeaters therefore causing them to be dim. When the turn signal is called upon, the repeaters "blink" at the normal, brighter level. I may change this to pulling from DRL's so that they will be illuminated when the headlights are off. You know, driving around being cool with my "Runnin Lights" on.
I will supply the company name and part number later. I think they were less than 10 bucks each.
Scott Walker
Scott Walker
Scott Walker
walker2311@att.net
2013 1LE Camaro
2011 9C3 PPV,wm rear spoiler,rear diffusor, lower chrome trim, wm rockers ss, fog lights, lower grill, chrome/black door handles, custom recessed factory grill, coil overs coming 2013 Camaro wheels in midnight silver in 20 x 8 and 20 x 9, 2014 SS exhaust tips
1952 Chevy Truck LS Conversion
1967 Chevy II Nova
1967 Chevy II Nova 1 Owner (just got her)
1964 Ford F100 (Bastardized in early 80's with chevy stuff)
1971 Datsun 510 (LS project ? Have a motor setup)
walker2311@att.net
2013 1LE Camaro
1967 Chevy II Nova
- Crazy Paul
Fabulous.
Does it come with a free rainbow sticker for the rear window?
http://www.customdynamics.com" onclick="window.open(this.href);return false;
Eclipze2® Module
$24.95 for pair
Eclipze2® Module
A new way to convert your single intensity LEDs to Dual Intensity with the advantage of 100% ON Running Lights and a Full Contrast Turn Signal Flash. Works with any size LED up to 300mA per side. Recommend for All Front Turn Signal Applications and for Red Rear Turn Signal Applications.
Eclipze2® will also convert a single intensity LED to Brake and Turn (no running), always giving the priority of Turn over Brake.
Eclipze2® Module
$24.95 for pair
Eclipze2® Module
Scott Walker
walker2311@att.net
2013 1LE Camaro
1967 Chevy II Nova
walker2311@att.net
2013 1LE Camaro
1967 Chevy II Nova
Crazy Paul wrote:Fabulous.
After finally installing these here is a daytime photo. Instead of having them painted body color I decided to go with the flat black of the original fender vents
- Repeaters.jpg (229.21 KiB) Viewed 17588 times
1996 DGGM Impala SS
1996 DGGM Impala SS
Did you go with the OP's dual color LED's or Scott's dimming module? This project sounds like a typical one of mine. This one was what, three and a half years? How are you doing sir? Long time, no see! Hope you are well!
Regards,
Regards,
The Dual color LED strips and OPS control module. Here is a YouTube link.
https://youtu.be/Q2v3mYgDD1E" onclick="window.open(this.href);return false;
1996 DGGM Impala SS
1996 DGGM Impala SS
