Impala Rear View Camera Information
A Member with the font rear chrome strip wanted to add a reverse camera. He found the 2014+ Impala backup camera might be a good choice to mount on the ledge above the plate recess. Going to see if I can vamp up a harness to work with that one as well. Has all the same wires the 15 PPV cameras have so would work the same.
Camera GM Part Number: 22740367 ( NEW PART # = 23323779 )- also about $90 retail but with so many impalas out there the used market is ripe!
Here is a pics from a used Ebay auction:
Here is the pin out from the Impala
Shows a OEM connector of 13629704 - Not a good number with GM
Shows an OEM terminal number of 13327119 - Not a good number with GM
Tracked down the connector that plugs into the camera as a TE 1924211-1
And it uses different manufactures terminals interchangeably which is neat.
JST - SAIT-A03T-M064
TE - 2035170
Yazaki - 7116-7276-02
Smallest quantity I found available of the connector body was 10 but they are available as samples with TE. I got some extra if you need one.
Will post some pics of the final harness and install
Ilikemtb999
Re: Impala Rear View Camera Information
Post by Ilikemtb999 »
Awesome! That’s a great find and cheap compared to the SS one. Can’t wait to see it mounted up
Tracy241
Post by Tracy241 »
Got my SS silverbox back from WAM, and with smwalker's custom harness, hooking up the camera was easy as can be. It's not 100% angled right, and think it's a little off center between the plate lights, but for prototyping it all works well for me. Image
