2014+ WN Door Jamb Plug Connector Info
Have to add some wires to my door jamb connector so I looked up some of the terminal information. Mouser only carries 1 size male and female terminals in small quantities so that's all we can get.
Connector (Housing) Info:
wn Door Jamb Plug.png (270.26 KiB) Viewed 2253 times
Well the connector information was not even close once again, Thanks GM.
WM door jamb housings.png (97.72 KiB) Viewed 2253 times
Male Connector (Vehicle Side) - 13600511 - Not available at all it seems.
Ahhh here is a first GM sells it separately! Housing only:
GM part Number 13587760 - CONNECTOR,WRG HARN(41-WAY MALE)(W/O LEADS) - $4.33 MSRP! Shocking!
Female Connector (Door Side) - 13600509 or 13678795 (not sure difference) both available at Mouser in singles.
Terminal Information:
Male: Aptiv 15396711 - TTS 1.5 Male Unsealed Tin Plating Tang Terminal, Cable Range 0.22 - 0.35 mm2
GM Does sell a pigtail with the Male terminal on it already - GM Part 13575593 - About $7.00
Female: Aptiv 15345988 - DSQ 1.5 Female Unsealed Tin Plating Tang Terminal, Cable Range 0.35 - 0.50 mm2
And Just noticed they are different wire size ranges. But that's all I can find available in small quantities. Sucks.
.35 is like 22 AWG - .50 is close to 20 AWG
Mouser project list - WN Door Jamb Plug Terminals
