2013 CHEVY CAPRICE PPV
I replaced my trunk light with an LED and it apparently blew a fuse or something but now I have no glove box light or shifter light or trunk light... Can’t seem to locate a bad fuse or maybe i’m looking in wrong area...
Any ideas?
Trunk light/Glove box light/shifter light all blacked out
Re: Trunk light/Glove box light/shifter light all blacked out
Yea them trunk light bulb holder arms are totally exposed when you are installing it you are sure to tap them on the metal.
Here is the diagram:
https://www.chiltonlibrary.com/content/ ... 662614.pdf
Looks to be F4DA feeding the BCM for that function. Which is in the instrument panel fuse box.
Here is the layout. Fuse is labeled BCM 2
https://www.chiltonlibrary.com/content/ ... 609169.pdf
My advise, put in your rear trunk lamp, then replace the fuse!!
Thanks a million Steve!! Found the fuse blown out in the driver side footwell labeled BCM ACCORDING TO THE OWNERS MANUAL.
