Rear defrost/heated mirrors do not work
jj55chevy
Post by jj55chevy »
does anyone know what would cause my defroster to not work? it has not worked as long as I have owned the car and it would be nice to use it and the heated mirrors. Just not sure where I should start looking, thanks!
Sanford
Re: Rear defrost/heated mirrors do not work
Post by Sanford »
What year? I would take a look at the relays and fuses that are under the left kick panel on the 11-13’s. Most of the relays in that area are the same, so you should be able to swap them around.
David
Here is the Rear defog.
Thought the mirrors were somehow tied in?
https://www.chiltonlibrary.com/content/ ... 662597.pdf
Oh yea they are off the same relay just not detailed together:
https://www.chiltonlibrary.com/content/ ... 662622.pdf
FU2 is the 40amp fuse Not to be confused with F2 (small fuse) . It's one of the square ones with the clear top where you can see if it blew.
The the Relay is R8
https://www.chiltonlibrary.com/content/ ... 609166.pdf
