Radio and wiring part numbers and information
Tom Slick
Re: Radio and wiring part numbers and information
Post by Tom Slick »
Maybe this will help...
Looks like you have the detection signal connected to the wrong pin...
Later,
Tom Slick
alanblinkers
Post by alanblinkers »
I ran the connection signal to the battery ground. As for the pins, I used the pin out information at http://www.carmodder.com/doc-holden-com ... 72m90.html
So I connected right and left to 5 and 6, ground to 12 and the audio detection to pin 8 on x4.
I showed two different photos of both ways I connected the audio since I wasn't sure which was which, but the photo with the correct audio configuration doesn't show the audio detection wire hooked up, and I'm 99.9% sure I had it in the correct position.
Tom Slick
Post by Tom Slick »
PM sent
Tom Slick
Post by Tom Slick »
If I remember correctly, the detection signal should be connected to one of the negative aux audio pins... not the battery ground.
Later,
Tom Slick
Tom Slick
Post by Tom Slick »
Alan,
Any luck?
Tom Slick
RWT946
Post by RWT946 »
Was anyone able to get the front auxiliary input to work without reflashing? I have a 2013 PPV and would like to add it. Thanks!
Tom Slick
Post by Tom Slick »
I haven't had a chance to try it... still need to get the connector (USB / 3.5mm)...
I do know that the rear Aux can be enabled... mine has been... rear view camera, too...
Later,
Tom Slick
Post by elc32955 »
RWT946, welcome to the system.... Don't forget your intro post so everyone knows you and can say hi :)
So I've got an on-topic post in here, Tom I've been working on de-stacking the garage this last weekend and I can finally access the box I need with the goodies. I'm diligently working on your care package.....
RWT946
Post by RWT946 »
Thanks. I would live to get the front auxiliary enabled and/or Bluetooth, but I doubt that'll happen anytime soon after reading these forum posts.
Tom Slick
Post by Tom Slick »
Eric... Cool!
RWT946... We are working on it... The Rear Aux supposedly sounds better than the front aux input... possibly because of the "switching" function on the front aux.
Thanks,
Tom Slick
