repeater wires
Q & A with the Holden Parts guru himself, Paul Sadler. Archive for old topics only, business is now closed.
This business venture is currently on hiatus. No new orders for parts are able to be placed at this time, nor is this site being monitored by the vendor. Forum is locked, discussion topics are left active for reference purposes. Unfortunately we have no idea at this time when the business will again be accepting orders.
bkwagonss
repeater wires
Post by bkwagonss » Fri May 03, 2013 2:29 am
Hey Paul, welcome to the New Caprice forum.
I'm having a heck of a time trying to figure out which wire(color) goes to the corner turn signal light in the headlight housing.
I assume it's one of the wires in the headlight housing connector.
I ran a wire from the side marker/repeaters to the headlight so I could hook them up to the turn signals.
2011 Caprice PPV 9C3 "karma"
2003 Silverado
1950 Chevy Fleetline
Tom Slick
Re: repeater wires
Post by Tom Slick » Fri May 03, 2013 2:42 am
Where can I get a set of those?
Later,
Tom Slick
bkwagonss
Re: repeater wires
Post by bkwagonss » Fri May 03, 2013 4:39 am
I got them from Paul.
2003 Silverado
Crazy Paul
Re: repeater wires
Post by Crazy Paul » Fri May 03, 2013 4:48 am
bkwagonss wrote:I'm having a heck of a time trying to figure out which wire(color) goes to the corner turn signal light in the headlight housing.
If it's the same as a Holden WM Caprice Series1 (???????????) then at the 10 Cavity Connector for each Headlamp.
Left Headlamp, Left Front Turn Signal Supply Voltage = Pin 9 = Light Blue Wire with a White Trace.
Right Headlamp, Right Front Turn Signal Supply Voltage = Pin 9 = Dark Blue Wire with a White Trace.
bkwagonss
Re: repeater wires
Post by bkwagonss » Fri May 03, 2013 5:51 am
Cool, thanks Paul, I'll look tomorrow.
2003 Silverado
Tom Slick
Re: repeater wires
Post by Tom Slick » Fri May 03, 2013 2:15 pm
Hey Paul,
I need to see about getting a set of those... do they come in chrome? If so, I'd like to get the chrome door handle covers to go with them... :-)
Later,
Tom Slick
Re: repeater wires
Post by Pursuit » Fri May 03, 2013 6:32 pm
Paul, I would be interested in a set of the side marker repeaters also!
Thanks,
Crazy Paul
Re: repeater wires
Post by Crazy Paul » Fri May 03, 2013 9:22 pm
Tom Slick wrote:Hey Paul,
Pursuit wrote:Paul, I would be interested in a set of the side marker repeaters also!
The top and bottom horizontal surfaces are chrome from factory. The outer bezel is plain white plastic = requires painting to suit car body.
Crazy Paul
Re: repeater wires
Post by Crazy Paul » Fri May 03, 2013 9:31 pm
I can do a pair of the Holden Caprice side indicator (repeaters) complete with a pair of wiring connectors for US$333 total shipped.
Airfreight ETA is 14 days.
My Paypal ID is pjsadler@iinet.net.au
E-mail address is also pjsadler@iinet.net.au
The wiring connectors are approx 6" long and plug into the odd shaped connectors on the inside of the repeaters. You can then run new wiring back to within 6" from the repeater and make your new wiring connection on each side of the car.
Tom Slick
Re: repeater wires
Post by Tom Slick » Fri May 03, 2013 9:39 pm
I guess I'll have to hold off for a little while...
Just spent a nice chunk of change getting some headwork done for my Shelby!
Later,
Tom Slick
Locked
