It is currently Sun Jan 21, 2018 7:21 pm
Please note & respect that Chris has full-time employment and has only specific contact hours for his business. General questions can be posted here, but for specific individual needs please contact him via his website. Hours of operation are SAT & SUN from 10AM to 4PM Central time. Please only expect responses to EMAILS & forum posts during these times.
Post new topic Reply to topic  [ 70 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
Author Message
PostPosted: Sat Dec 28, 2013 12:05 am
Offline
Finally finished installing my Chris White programmed radio, along with the usb cable, video connector, and add-on wiring to the factory Quadlock connector (front auxiliary, dvd audio, amp signal).
Everything works! Bluetooth streaming and bluetooth calling were the main reasons I got mine done... worth every single penny!
Thank you very much Chris!
Tom Slick
_________________
1932 Glassic Ford Model A Roadster Replica - Ford 302/C4, approx. 1400lb... :-)
Top
 Profile
PostPosted: Sat Dec 28, 2013 7:45 pm
Offline
You're most welcome thank you for all of your help on this! Can you verify that indeed the DVD input keeps playing as the vehicle is moving? I tested it on the bench but its nice to hear it from someone in the field :)
_________________
Chris White
2015 Jeep SRT - Stock for a hot minute.
2016 SRX - Custom BCM/HMI - More to come
2016 Yukon Denali XL - Custom BCM/HMI/IPC
Top
 Profile
PostPosted: Sun Dec 29, 2013 8:32 pm
Offline
Yep! No message saying no video while in motion...
Tom Slick
_________________
Top
 Profile
PostPosted: Mon Dec 30, 2013 2:17 am
Offline
Tom Slick
Peeeeerfect. Like I said tested it on the bench but never hurts to verify operation in car :)
_________________
Chris White
Top
 Profile
PostPosted: Mon Dec 30, 2013 4:12 am
Offline
Hey all, I just saw a post over at SS Forums that the My Link system is limited to 32gb USB drive do to only reading FAT32 file system as that is the max size for FAT32 (cannot read NTFS). My guess is that ours is the same and we can only use 32gig max USB drive. I did not even think about the 32gb FAST32 max size and was looking to get a larger drive as I am currently using a multiple 4gb. I saw a program that will format FAT32 on a larger drive (fat32format), but I am just going to get a 32gb as my music library is not much larger.
If someone has a larger USB and wants to try to format it with 'fat32format' and pass along if it will work.
Top
 Profile
PostPosted: Mon Dec 30, 2013 7:24 pm
Offline
Mylink is a completely different radio although I have seen notes on the IQ when using USB of a 1000 song limit, iPod should get around that.
_________________
Chris White
Top
 Profile
PostPosted: Sat Jun 21, 2014 9:18 pm
Offline
I would like to get my radio programmed and im just wondering what the component looks like that I need to ship to chris white. I leave for a week for work tomorrow and its the perfect time to go without ac ha. And does chris also supply usb cables and a hookup for amps? Any input would be greatly appreciated!
2011 9c1
_________________
2011 9C1 Charcoal Grey--
Chris White programmed Radio
2012 Camaro SS 20's Nitto Invo tires
Top
 Profile
PostPosted: Mon Jun 23, 2014 12:10 pm
Offline
The large "silver" box behind the radio/AC control panel...
Later,
Tom Slick
_________________
Top
 Profile
PostPosted: Sat Aug 23, 2014 5:25 pm
Offline
I've had my programmed radio for a while now and love it ! Totally worth every penny. Im having an issue, the radio does not like to turn off with 1 ipen of the door. I have to open and shut it multiple times to get the radio to turn of one the key is removed. Any ideas?
_________________
Top
 Profile
PostPosted: Mon Aug 25, 2014 6:16 pm
Offline
Thats not the radio its the door switch/wiring or BCM. The BCM tells the radio to turn off ;)
_________________
Chris White
Top
 Profile
Search for:
Jump to:
