Need custom module programming for your Caprice PPV? Chris White is here to answer your questions.
Please note & respect that Chris has full-time employment. General questions can be posted here, but for specific individual needs please contact him via his website. SPECIAL NOTE - We have no role or liability in any transactions other then to provide a venue to advertise the items. Disputes must be resolved independently between the parties involved in any transaction.
Tom Slick wrote:There is a service cable you can buy... I built my own... used it to update my radio at the dealership... They told me they wouldn't buy one for just one Caprice PPV...
Chris, is your programming update put on a flash drive and then uploaded through the Tech 2, like the "factory" updates?
Later,
Tom Slick
Crap, I ghetto rigged one for bench use but there is no way I could use it in a car and I have a guy who wants to come up tomorrow with his new car to be programmed! I have to see how quickly I can get the J-Tool for it :\ Our programming is a 6 step process one of the steps is indeed the USB flash drive but we don't utilize the Tech 2.
MDI?
Later,
Tom Slick
Later,
Tom Slick
MDI?
Later,
Tom Slick
I wish! It would be far cheaper; we have our own special sauce We don't use any GM stuff for these, FAR to limited in this application.
Ok so I just ordered the correct cable for these things next day air for $160 #!%!#ing dollars ARGH. Hope it shows up on time LOL
Tom I'll check my email here in a minute!
Chris White http://www.whiteautoandmedia.com
2022 3LT Red Mist Coupe
2023 70th Anniversary Z06 HTC
2023 Escalade V
2022 Camaro ZL1 M6
I got my radio out and is boxed and will be dropping it off for FedEx Home/Ground server. Hopefully it will get out of Dallas on time and you should see it Friday or Saturday.
Yeah, it is a major PITA go get these radios out and more so when it is cold but I let the car heat up so the plastic was warm and not ice cold.
K9Vic wrote:I got my radio out and is boxed and will be dropping it off for FedEx Home/Ground server. Hopefully it will get out of Dallas on time and you should see it Friday or Saturday.
It takes a loooooooong time to get the interior warm enough if its freezing out, the backside of that dash gets basically no airflow since its all directed into the cabin. Now I just have to figure out what the easiest way is to access the USB connector in car so I can program a radio tomorrow (hopefully!)
2023 Escalade V
2022 Camaro ZL1 M6
Chris you can access the USB port by removing the side console trim and cover under the steering wheel. When I was taking out the IQ I could see and access the plug with just those parts removed. Sorry no pictures, but that should be all you need to do.
Side note. I think the climate system remembers the last setting when unplugged. Mine was set to blower high on defrost. Also the dome lights go off when IQ unplugged and inop.
What is the distance between the pins for the USB connection? I meant to measure that when I had the unit... I might be able to source the connector...
Thanks!
Tom Slick
1 Bare : Shield DVD Input Video Ground (-)
2 Red : DVD Input Video Signal (+)
3 Bare : Shield Reverse Camera Video Ground (-)
4 Red : Reverse Camera Video Signal (+)
5 : Not Used
6 : Not Used
7 Green : Video Connector (RGBS) - Blue
8 Black : Video Connector (RGBS) - Green
9 Yellow : Video Connector (RGBS) - Low Reference
10 Red : Video Connector (RGBS) - Red
11 Bare Shield : Video Connector (RGBS) - Ground
12 White Video : Connector (RGBS) - Syncronisation
13 - 20 : Not Used
7 through 12 are for the HSV EDI system...
Later,
Tom Slick
5 : Not Used
6 : Not Used
13 - 20 : Not Used
Later,
Tom Slick
I've got it, thanks! EDI requires a handshake so that part kind of sucks Can still use the DVD player input though!
2023 Escalade V
2022 Camaro ZL1 M6
