Page 7 of 7
Re: WAMS Presents the NEW Standard in PPV Radios :)
Posted: Fri Dec 27, 2013 6:05 pm
by Tom Slick
Finally finished installing my Chris White programmed radio, along with the usb cable, video connector, and add-on wiring to the factory Quadlock connector (front auxiliary, dvd audio, amp signal).
Everything works! Bluetooth streaming and bluetooth calling were the main reasons I got mine done... worth every single penny!
Thank you very much Chris!
Tom Slick
Posted: Sat Dec 28, 2013 1:45 pm
by GTPprix
You're most welcome thank you for all of your help on this! Can you verify that indeed the DVD input keeps playing as the vehicle is moving? I tested it on the bench but its nice to hear it from someone in the field :)
Posted: Sun Dec 29, 2013 2:32 pm
by Tom Slick
Yep! No message saying no video while in motion...
Tom Slick
Posted: Sun Dec 29, 2013 8:17 pm
by GTPprix
Tom Slick wrote:Yep! No message saying no video while in motion...
Tom Slick
Peeeeerfect. Like I said tested it on the bench but never hurts to verify operation in car :)
Posted: Sun Dec 29, 2013 10:12 pm
by K9Vic
Hey all, I just saw a post over at SS Forums that the My Link system is limited to 32gb USB drive do to only reading FAT32 file system as that is the max size for FAT32 (cannot read NTFS). My guess is that ours is the same and we can only use 32gig max USB drive. I did not even think about the 32gb FAST32 max size and was looking to get a larger drive as I am currently using a multiple 4gb. I saw a program that will format FAT32 on a larger drive (fat32format), but I am just going to get a 32gb as my music library is not much larger.
If someone has a larger USB and wants to try to format it with 'fat32format' and pass along if it will work.
Posted: Mon Dec 30, 2013 1:24 pm
by GTPprix
K9Vic wrote:Hey all, I just saw a post over at SS Forums that the My Link system is limited to 32gb USB drive do to only reading FAT32 file system as that is the max size for FAT32 (cannot read NTFS). My guess is that ours is the same and we can only use 32gig max USB drive. I did not even think about the 32gb FAST32 max size and was looking to get a larger drive as I am currently using a multiple 4gb. I saw a program that will format FAT32 on a larger drive (fat32format), but I am just going to get a 32gb as my music library is not much larger.
Mylink is a completely different radio although I have seen notes on the IQ when using USB of a 1000 song limit, iPod should get around that.
Posted: Sat Jun 21, 2014 4:18 pm
by bnsfBO
I would like to get my radio programmed and im just wondering what the component looks like that I need to ship to chris white. I leave for a week for work tomorrow and its the perfect time to go without ac ha. And does chris also supply usb cables and a hookup for amps? Any input would be greatly appreciated!
2011 9c1
Posted: Mon Jun 23, 2014 7:10 am
by Tom Slick
The large "silver" box behind the radio/AC control panel...
Later,
Tom Slick
Posted: Sat Aug 23, 2014 12:25 pm
by bnsfBO
I've had my programmed radio for a while now and love it ! Totally worth every penny. Im having an issue, the radio does not like to turn off with 1 ipen of the door. I have to open and shut it multiple times to get the radio to turn of one the key is removed. Any ideas?
Posted: Mon Aug 25, 2014 1:16 pm
by GTPprix
bnsfBO wrote:I've had my programmed radio for a while now and love it ! Totally worth every penny. Im having an issue, the radio does not like to turn off with 1 ipen of the door. I have to open and shut it multiple times to get the radio to turn of one the key is removed. Any ideas?
Thats not the radio its the door switch/wiring or BCM. The BCM tells the radio to turn off ;)
