Cooling fan wobble?
Cooling fan wobble?
Driving home this afternoon, and I'm sitting at a light, at idle, with the A/C on, and hear a sound that sounds like the engine went into AFM mode with the intake open, or like someone slowing down beside me with a diesel exhaust brake. I could hear the noise for about 15-20 seconds, then went away. The sound did not follow engine RPM. Everything else on the car seemed fine.
When I got home, I had a look, and everything seems to be in place. I spun both cooling fans, and they spin okay, but the passenger side fan has about 1/2" of wobble. Time to replace? Whole assembly? Fan only? What?
Thanks.
Re: Cooling fan wobble?
Thought there was an extended warranty on cooling fans yes? Not seeing it in the recall section.
EDIT: Here it is: viewtopic.php?f=9&t=917&hilit=cooling+fan" onclick="window.open(this.href);return false;
bsparks72
Post by bsparks72 »
That's exactly what happened to mine. Thought it was a cracked blade, like happens to the G8s quite a bit. Turned out it was the motor shaft wobbling. I replaced it on my dime, but I was already past the mileage limit on the recall.
-Brandon
I forgot all about that! I have my letter in the glove box of the car. I'll have to schedule an appt with GM.
Arcticolds442
Post by Arcticolds442 »
A fan motor went out on me a month ago with my 2012 when I was on a road trip. As a temporary fix, I switched the wires going to the fans at the fan harness connector so the other (good) fan would turn on first, since its mainly just the one fan that cycles so often. I didn't know about the recall either, so I pulled the works apart and replaced the motor with one out of the wrecked '13 PPV that happens to be sititng in my yard :)
If I lose another one, I know to take it in to the dealer. Thanks for that link!
I also redid the fan curve in HPTuners so that the fans come on a little closer together in temp and stay on a little longer as well, just so I dont have to listen to the nuisance cycling.
2012 9C1 DD - stock for now
'72 Olds 4-4-2
'65 AMC Rambler - LQ4/T56 work in progress
"No Bucks Given" '84 VetteKart
'65 Cutlass
Except for the noise from this wobbly fan when it comes on, I don't hear the fans unless I'm outside the car.
I have a date with the dealer Monday morning. Funny, when I called to schedule the appointment, the Service Writer was the same guy who waited on me for the fuel pump thing. I'm guessing they don't get too many late-model Caprices in, as he knew me and the car when I said '2012 Caprice'. His comment: "I hope we don't have as much trouble with the fan as we did at the other end of the car." To which I replied: "Under the hood, the car is surprisingly clean for it's age and mileage. No rust here!" :-)
Picked the car up today. All work was done under warranty. Funny, when the porter came out to get the car, he asked 'what kind of car is it?'. I told him that it was a Caprice. He said "funny, the guy who took it in wrote ' cop nice' on the label.". We laughed, and I told him that it was a cop car , that was apparently all he needed. :mrgreen:
Glad the warranty came through for you. A good reminder to all 2011 folks the 6 years is about up on this one, get out there and check them fans.
Indeed. I _thought_ I checked my fans when the notice came in and found no problem at the time, but am not 100% sure on that.
So, if you haven't at least checked, then do so now!
