Blend door actuator relearn?
Posted: Tue Aug 09, 2016 7:42 pm
My passenger side vents are warmer then my driver side vents. They also seem to blow slightly weaker than the driver side - but this is marginal. I suspect that either two things are causing us, a blend door that is stuck or not working correctly, or my freon level needs to be checked.
On this forum (http://forums.justcommodores.com.au/ve- ... ement.html" onclick="window.open(this.href);return false;) , it seems like the commodore has a blend door relearn procedure by holding down the rear defrost button. This did not seem to do anything for me. Is there an equivalent procedure for our cars? Also, I think the blend door actuator for dual zone is located on the top of the dash rather than by the footwell areas (I checked pass side and only saw recirculation/windshield/foot area actuators, all seem to work fine there). Can anyone confirm the location of the DZ blend actuators?
