HVAC buttons
cerbomark
HVAC buttons
Post by cerbomark »
My top two controls buttons on the system stick down once in a while. I tried compressed air, electronic cleaner, WD 40 and not 100%. I can t figure out if and how I can pop the buttons off . Not sure if it s dirty or something bent with those top two vent buttons on my 2016. Any ideas? Thanks.
2016 C1
cerbomark
Re: HVAC buttons
Post by cerbomark »
I think I got it. Took unit out, push buttons don t come out but with everything apart you can wash with hot water and soap. Right now all buttons work much better. The two long trim pieces above unit come out and then there are two screws holding unit in, then two plugs. Remove from car, take back off (6 or so screws), then dis assemble. Would have never gotten it cleaned out from the front FYI.
2016 C1
cerbomark
Re: HVAC buttons
Post by cerbomark »
a few pics.
2016 C1
