Correcting factory HVAC issues
Black6
Post by Black6 »
Ok. I’m super over how these HVAC temperature controls operate.
While not on auto and temperature set on a constant, this stupid system constantly is changing the temperature. As you all know, it will go from blowing ice cold air to liquid magma as it pleases.
Even changing the temp 1 or 2 degrees can make it going from one extreme to the other. I’m over it.
What I’d like to know is how can we fix this issue on our cars? I just want the “temperature” dial to be like cars have been since 1932, 0% heat flap to 100% heat flap.
I’m assuming this will take some BCM tuning, which I’m ok with. But I know I’m not the only person who this annoys. Other options I can think of are disabling temperature sensors, but I don’t know how that would impact the actual operation of the system. If it goes to a default then that’s perfect.
Black 2014 V8
Sanford
Re: Correcting factory HVAC issues
Post by Sanford »
May want to hook the car up to scan tool that will read the HVAC module and see if you have any trouble codes. I don’t know how well the 14’s controls the output, but I am well satisfied how the 11-13’s work. If they keep working for another 15 years, I will really be impressed.
David
sardillim
Post by sardillim »
i have a 12 and no issues
I second getting a scan tool or taking it to a dealer that can read commanded and actual actuator positions. Sounds like you have a screwed up temp actuator.
Post by xcidmigs »
My 2011 doesn't do this either
Black6
Post by Black6 »
There is nothing wrong with the car, the HVAC is just programmed like shit.
I guess that I should say that I’m looking for 14+ owners and their input.
Are any other 14+ owners who want to have their HVAC programming fixed or know how to trick the system?
Black 2014 V8
