2014 Caprice PPV - YouTube Project Car
rcg530
How-To Remove/Install Rear Seat
Post by rcg530 » Fri Jun 12, 2020 12:17 am
I show how to remove and install the rear seat in a 2011-2017 Chevy Caprice PPV as well as the 2014-2017 Chevy SS Sedan.
2014 Chevy Caprice PPV | 2004 Chevy SSR Pickup | RetroCarGuy530 YouTube Channel
rcg530
Rear Axle Wiring Harness Tape Problems
Post by rcg530 » Mon Jun 15, 2020 3:57 pm
I have a video I created back in 2018 that talks about a customer satisfaction campaign 15803 (not a recall) for the 2014/2015 Chevy SS / Caprice PPV rear axle wiring harness tape problem.
It's worth the few minutes it takes to check if this work was performed to your 2014-2015 Caprice PPV.
rcg530
Aluminum Pedal Cover Installation
Post by rcg530 » Wed Jun 17, 2020 11:06 pm
I show you why I installed an aluminum dead pedal cover with spacers. I also install aluminum brake and accelerator pedal covers used in the Chevy SS Sedan in my 2014 Chevy Caprice PPV.
rcg530
Add a Backup Camera / Activate XM Radio Receiver
Post by rcg530 » Tue Jun 23, 2020 9:57 pm
This video gives you an overview of how I added a backup camera and activated the XM Radio receiver in my 2014 Chevy Caprice PPV.
rcg530
2014-2017 Chevy Caprice PPV - Remove Fleet Keys / FOBs
Post by rcg530 » Sun Jun 28, 2020 12:14 am
I give you an overview of the steps I performed to have my 2014 Chevy Caprice PPV no longer accept fleet keys nor FOBs from RPO code 6E3.
I also show you what I did to repair the FOB antenna in the rear window of my car.
rcg530
14-17 Chevy Caprice PPV - HVAC Afterblow / XM Radio Antenna / Front Sway Bar Bushings
Post by rcg530 » Wed Jul 22, 2020 3:48 pm
I show you some of the minor mods I made to my 2014 Chevy Caprice PPV while I was waiting for the parts to repair the failed fuel pump.
I also document what the HVAC afterblow feature is and how you can use a scan tool to enable that feature in the HVAC control module.
rcg530
2014-2017 Chevy Caprice PPV - Install Front Splash Shields
Post by rcg530 » Thu Jul 30, 2020 5:06 pm
I needed to replace the front splash shields on my 2014 Chevy Caprice PPV after I worked on my car to replace the front sway bar bushings.
The driver's side splash shield broke into pieces and the passenger side splash shield was not installed.
