"Upfit Build"
"Upfit Build"
Here's my build up on the Caprice, it's not your common build thread, no power addons, no big tires, no cam. Just upfitting the car, as it would have been.
The car was bought brand spank me new last August and the upfit was done June of this year. Parts and time were being acquired. I took the interior out with the exception of the carpet/mat (just folded it back). All work was performed by yours truly.
I dont have ALL of the pics during the process, but I'll add some later of the finished product(s).
- FAT MAT in the rear floor
- p11.jpg (104.75 KiB) Viewed 17981 times
- Lined the entire trunk and rear floor with FATMAT... BIG DIFFERENCE
- p7.jpg (92.84 KiB) Viewed 17981 times
- Motivation
- p14.jpg (75.15 KiB) Viewed 17981 times
- Mock up of the Gamber Console and computer mount.
- p6.jpg (86.94 KiB) Viewed 17981 times
2014 Phatom Black 9C1 (Toy)
Re: "Upfit Build"
Heres the nitty gritty
- KERR extension harness and radio control head cables
- p16.jpg (129.83 KiB) Viewed 17978 times
- p3.jpg (125.86 KiB) Viewed 17978 times
- p17.jpg (113.4 KiB) Viewed 17978 times
- p9.jpg (58.17 KiB) Viewed 17978 times
- p13.jpg (103.84 KiB) Viewed 17978 times
Re: "Upfit Build"
Console install
- Mockup
- p10.jpg (259.65 KiB) Viewed 17978 times
- Console wire routing/mounting
- p12.jpg (65.39 KiB) Viewed 17978 times
- Front KERR fuse panel mounting
- p19.jpg (78.5 KiB) Viewed 17978 times
- Not 100% finished
- p8.jpg (85.87 KiB) Viewed 17978 times
- Just missing front plate, added Kussmaul goodies
- p18.jpg (113.47 KiB) Viewed 17978 times
Re: "Upfit Build"
Trunk
- AHHHHHHHHHH *cringe
- p2.jpg (63.33 KiB) Viewed 17977 times
- Mounting of the trunk's equipment
- p5.jpg (68.66 KiB) Viewed 17977 times
- p20.jpg (66.19 KiB) Viewed 17977 times
- p21.jpg (72.77 KiB) Viewed 17977 times
- Finally....the SS steering wheel
- p4.jpg (107.23 KiB) Viewed 17977 times
Re: "Upfit Build"
I would bet dollars to doughnuts that is the neatest up-fit done on a Caprice!
Re: "Upfit Build"
To be a true "upfit" you must break at least one or more clips or fasteners on each panel ...must cut off all plug connectors and ends and then butt connect them (even though the other half of the plug is in the glove-box) You must drill and mount components to the dash's most expensive section thats the hardest to replace ...not the cheap easily removed one. .......From what I've seen. (have 5- 12's and 3- 14's sold one 12) BTW, have this KERR ind. relay board if interested $40 + "actual" fedex shipping no added jack ups.
- IMG_20170813_133934074.jpg (366.54 KiB) Viewed 17959 times
Re: "Upfit Build"
That right there is a true statement. I have box of interior panels I need to replace because of crappy upfittersCHEVEN wrote:To be a true "upfit" you must break at least one or more clips or fasteners on each panel
Re: "Upfit Build"
Nice job! I have just about the same number of antennas on our car, but they're to plug holes and are inop. Our car came with that exact fuse block/circuit panel, laying in the passenger floorboard.
Any idea how much the sound deadener film weighed? That could probably cut down on a log of 'booming' as the car goes down the road, but I don't want to add much more weight to an already heavy car.
Re: "Upfit Build"
Oh, and i have a true caprice mount speaker ...hooks on the pinch-weld on the drivers side frame tube and one bolt passes through to hold. Tucks up behind front bumper cover. (with wire and plug) $35. plus shipping.
- IMG_20171004_165554651.jpg (223.93 KiB) Viewed 17941 times
Re: "Upfit Build"
damn!!!! 4 radios. Nice work.
2014 Caprice PPV silver
2017 Ram 3500
2002 CETA trans am
1995 9c1
1977 Trans am SE 4spd.
1978 trans am 400 4 spd.
2017 Ram 3500
2002 CETA trans am
1995 9c1
