Yet another endless build for me. This time on the Caprice.
Re: Yet another endless build for me. This time on the Caprice.
Post by CrashTestDummy » Thu Jan 03, 2019 1:58 am
FYI, the 'ball socket' for the exhaust end on the Solo Performance high-flow cats are not accurately-made. While our X-Force exhaust had been modified by the PO so that it fit the factory cats, the driver's side on our car didn't snug up to the cat-side flange as the passenger side did. 2+ HOURS with a die grinder got it so that it fit better. The OD of the ball on the driver's side cat was 0.2" larger than the fitting on the X-Force head pipe. I finally got it fitted and bolted up, but was out of time and energy to finish the exhaust install.
Story continued......
2010 Tahoe PPV (her car)
Post by CrashTestDummy » Sun Jan 06, 2019 12:12 am
We finally got the exhaust fitted and buttoned up. There's about 1/4" of leeway down the entire path, with maybe 1/8" for the tail pipes. What a PITA, but it's in. Started the car, and it sounds pretty nice. I bit loud, but I'm not sure where the internal valves are set.
I CAN'T FIND THE REMOTE CONTROL!!!!!!!!
We turned the shop upside down trying to locate the thing, a couple of times. The damned thing is AWOL. I'm not finding a spot to order a replacement from X-Force, so I've emailed them to see what can be done. If push comes to shove, I"ll just jump each muffler separately to get to the desired setting and leave it at that. We'll see what they say.
Post by CrashTestDummy » Sun Jan 06, 2019 10:58 pm
After finishing up the exhaust install, we did take this picture:
I also got the LED driving lights wired and the harness wrapped in conduit:
Note that the back of the front bumper cover is upside down in this picture, and the conduit is routed to the passenger side of the cover. I still need to terminate those wires, but this is good for now.
lastcall190
Post by lastcall190 » Mon Jan 07, 2019 1:56 am
Both items look good, nice and tidy. Post a pic of the front bumper and lights when that project is 100%, as I'm interested to see what you came up with.
Are those 3.5" tips? Fill out the bumper opening quite nicely.
DOD Delete, LS9 Cam, Pat G tune, Magnaflow G8 Exhaust
163k miles and counting
Post by CrashTestDummy » Mon Jan 07, 2019 3:14 am
Not sure what the tips are. The exhaust is 3" cat to tail pipe, though.
Yeah, front pic is pending. Still waiting for the fog lights to arrive.
Post by CrashTestDummy » Wed Jan 09, 2019 11:21 pm
Well, my order arrived today. I ordered:
1 ea. front under tray - the one on the car is cracked in places, so I figured I'd replace it while parts are still available.
2 ea. 'outer reinforcements - one for each side. That way I get those capture nuts.
2 ea. fog light assemblies, one for each side.
I got:
1 ea. outer reinforcement
1 ea. fog light assembly
FML!! :cry:
Also, the replacement X-Force controller and remotes is still on a truck. The delivery guy claimed he couldn't access the property. Funny, the same company delivered other parts to my house on Monday!!!
I'm going outside now to see if there's a break lurking around here I can catch!
Post by CrashTestDummy » Thu Jan 10, 2019 6:34 pm
The Varex controller and remotes were delivered this morning. Still waiting for the fog lights and reinforcement bracket.
Post by CrashTestDummy » Sat Jan 12, 2019 11:55 pm
The controller works GREAT! The remote is already on the key chain, so no losing that booger!
The replacement fog light and reinforcement panel arrived, too. Thank you gmpartscenter.net!!
The lights are installed, but I need to find the notes on the wiring kit so I know what to plug in where. It looks like the kit allows one to tap into the side marker light for power? signal? Either way, I'm not sure I can do that, since it looks like someone chewed (yes chewed) the body side connector for the front side marker light harness off. I'll investigate more tomorrow after I get the install notes. I think I'm using a Steve Walker kit. :-)
Post by CrashTestDummy » Sun Jan 13, 2019 11:39 pm
Got some quality time out in the shop today, and got most of the wiring completed for the fog light install when I hit a snag. I've posted my queries to the 'how to install fog lights on a Caprice' thread, so hopefully Steve, or someone who's done this job will reply. Overall, Steve's instructions have been spot-on!
On another note, I discovered the Varex valves seem to be pretty much one setting, or the other. You can get open, or closed with the remote, but fine-tuning it to get something in between is going to be very tricky. I was hoping to be able to tune out drone, if I experienced it, but that might be just wishful thinking. We'll see once we get the car back on it's feet and on the road.
