Tansman
Posts: 95 Joined: Tue Dec 20, 2016 6:34 pm
Post
by Tansman » Tue May 14, 2019 9:15 pm
CrashTestDummy wrote: ↑ Mon May 13, 2019 12:08 pm
I'm surprised the rear tires don't light up every time you open the trunk with all those stickers!
So am I!
I had to pull it out of the garage so I figured I'd get a picture. Seats are out to run the meth injection wires. If you're on the Facebook page I posted an idle video!
sar94
Posts: 8 Joined: Thu Jan 03, 2019 8:29 pm
Post
by sar94 » Wed May 15, 2019 9:44 pm
Sounded great on facebook..keep at it you are almost there.
Tansman
Post
by Tansman » Sat May 18, 2019 4:05 pm
Finally got the meth line ran to the front, mounted the pump in the spare tire well.
Tansman
Post
by Tansman » Sat May 18, 2019 4:28 pm
Trunk looks clean again!
Tansman
Post
by Tansman » Tue May 21, 2019 9:51 pm
I had the down pipe off to weld my o2 on, so I painted it gloss black with some hightemp paint. It looks a little more stealth now .
I plan to wrap this too up to right before it comes out of the fender.
Tansman
Post
by Tansman » Tue May 28, 2019 8:18 am
I put the meth nozzle in the silicone 90 before the throttle body. I used this piece from Amazon and flap disked it down until it was as thin as I could get it so the nozzle would be exposed and hopefully be able to have a good straight spray into the TB.
Screenshot_20190528-070939_Amazon Shopping.jpg (524.44 KiB) Viewed 17674 times
Tansman
Post
by Tansman » Tue May 28, 2019 8:21 am
Blow off valve flange is welded onto the 4in spectre pipe. I put it about 6in or so before the maf. I read that's about the best placement for it.
Tansman
Post
by Tansman » Tue May 28, 2019 8:23 am
The turbo outlet has a leg coming off it now, this was the last piece I needed to fully connect the coldside!
Tansman
Post
by Tansman » Tue May 28, 2019 8:27 am
I'm doing an IAT breakout so the IAT will be after the methanol nozzle. Its going into the short tube right in front of the TB. I wanted it in the intake but I don't know where people usually put these. So this should work!
Posts: 2300 Joined: Sat Feb 07, 2015 2:31 pm
Post
by CrashTestDummy » Thu May 30, 2019 10:01 am
Nice work. I have GOT to learn how to TIG!
